The Yari is getting good reviews even though the internals are a generation behind Pikes, nothing wrong with that at all, Revelations are similar in technology terms and still make a very good trail fork for significantly less than a Pike….i have Revs at 140mm and they’re great, further shortened to 130mm I would imagine they’re even better.
I also have X-Fusion Sweeps at 160mm on my full suss and they’re superb, the 34mm chassis is a step up from Revs, Fox-32s etc and the damping is plush initially and ramps up nicely to avoid bottom outs…they’re also easily adjusted internally from 120mm to 160mm if you get the long travel models, they usual crop up on CRC for less than £400, they are fairly future proof too as the new Roughcut damper (google it, getting rave reviews) will be available later this year and can be installed in older models by simply pulling out the old cartridge and dropping in the new one.
….read the Cotic page about why they’ve started speccing the Rocket with X-Fusion suspension, they’re quietly going about the business of making top performing forks and shocks that don’t cost the earth…they were set up by former Fox employees so they know their stuff, I’ve gone in wholesale and put one of their shocks on my FS too, when the Revs on my HT break I’ll be replacing them with X-Fusion, lovely kit regardless of price and serviced by TFtuned or a competent home tinkerer!
