And if you know what you are doing use a soapy water solution to apply the tape.
You spray the solution on to the frame or fork leg where you wish to apply the tape and this will allow you to slide the tap into the correct place. When you are sure it is in the correct place use a plastic scraper to gently smooth out all of the water and air bubbles.
The tape will be permanently fixed and without any bubbles.
Also remember to ensure the surfaces are free from grease, dirt or any silicone spray residue or the tie will not adhere properly.
The above is the same procedure that commercial signage companies would use for signs or when applying vinyl wraps to vehicles.
