Okay, I'll tell you but you have to promise not to take the p155.
My podiatrist told me I have a left leg that's 6mm shorter than the right. This is evenly split between the upper and lower leg. To compensate for this on the bike, I need to move the right foot forward 1.5~2mm and raise the left by the same amount. I've done this by cutting a spacer from an old Ikea chopping board.
To make matters worse, I also have a consideable forfoot varus angle on both feet. So, I mate two more spacers and then filed them down to make a wedge. All this looks like it should work quite well except for the fact that the cleat bolts don't reach the plates anymore! Hence the need for something longer. I've got a set og lemond wedges for the fine tuning but I need a good tilt for a starting point. I know a few mils and a few degrees don't sound like much but it's been messing me up for years it seems. Told you not to ask!
