Viewing 10 posts - 1 through 10 (of 10 total)
  • Alternative bite valves for a dakine bladder
  • shaggmiester
    Is there any other make bite valves that will fit on my dakine bladder as the original has been crap! And is now broke after just 6 months, shame cos the bag itself is the best i’v had, any suggestions much appreciated.
    mtbtomo
    Yep, I’d like some suggestions too, mine is just too stiff to operate with gloved fingers and leaks if you don’t close it off.
    nickegg
    I have a used once Dakine reservior (3L) for sale, should you be interested.
    Email in profile.
    Andituk
    Presume its a Hydrapak bladder like my nomad:
    http://www.chainreactioncycles.com/Models.aspx?ModelID=57592
    That one seems to work better.
    coatesy
    Their hoses are a bit crap too, swapped mine straight away for a Camelbak set up.Heat the hose in hot water and it’ll fit on the bladder fine.
    mtbtomo
    That valve (on CRC) is the one I have trouble with. Its too stiff turning from open to closed, especially when left for any length of time in the cupboard.
    shaggmiester
    Cheers all, just ordered a surge valve, hopefully thats better, mtbtomo, thats exactly what mines like, nearly breaking my teeth trying to pull it out! can’t leave it out cos it leaks! dakine nomad, brilliant bag, poor bite valve.
    jonb
    I got a Camelbak one to fit mine. Top tip os to dip the end of the hose in boiling water for a few seconds to soften it. Much easier to get the new bite valve in that way, especially if it is a bit too large.
    funkynick
    Try and find a Nalgene bite valve, especially the ones with the magnetic clip, they are the best bite valve I have used.
    Look here
    mtbtomo
    Shaggi, just so there’s no confusion, its the Surge valve I have – it twists shut. Its too stiff to twist between closed and open, and its been that way almost from new.
The topic ‘Alternative bite valves for a dakine bladder’ is closed to new replies.
