Airbag Light Flash ...
[Closed] Airbag Light Flash Codes in Ford Mondeo
[#3661428]
I've got a 51 plate Mondeo and the airbag light has started to come on.
I get 4 then 9 flashes, this repeats a few times and the light stays on.
From what I can see on the web this indicates a seatbelt tensioner circuit fault. I've got an electric operated drivers seat. 2.0 TDDI Ghia X
How do I tell if this is right, which seat has the problem and how to correct it cheaply?
Posted : 09/02/2012 9:08 pm
I guess you've read this:-
http://www.mirez.co.uk/Airbag.htm
and this
http://www.talkford.com/topic/112287-air-bag-light-flashes-4-then-9/
http://www.fordwiki.co.uk/index.php?title=Airbag_Flash_Codes#DTC_C1947:_Seat_position_sensor_short_circuit_to_ground_or_battery._Lamp_flash_code:_49
I'd be looking under both seats to see if I can spot the wiring and see if a connector has come undone.
Posted : 09/02/2012 9:12 pm
I'll wait till the weather gets a bit nicer before I start grovelling around on the floor I think.
Posted : 09/02/2012 9:24 pm
Well, I braved the cold and wet and had a look. The result was mixed - I didn't discover a loose connection, but I did find 20p and a tangfastic. But that will have to wait till tomorrow - my iDave day off.
Posted : 10/02/2012 11:59 am
