You need a decent blast of air – I doubt that will do.
What, my lemonade bottle? On what do you base that assertion – presumably not any experience? You didn’t stop to think that maybe if I was mentioning it on here, and given my other comments about how long I’ve been running tubeless, that it might actually work quite well according to my experience? It might not be quite as good as a proper compressor, but it’s £75 cheaper, and has never failed to work where a track pump, even using all the tricks doesn’t.
For those interested in details, it’s not very complicated. Take a lemonade bottle. Wrap in gaffer tape to help take the pressure. Drill a valve sized hole in the middle of the bottom, cut an old valve from a tube (or use a proper tubeless valve if you’ve got one spare, but back in the day we used valves cut from tubes for tubeless conversions also), and install in the bottom using appropriate washers and a nut – some extra offcuts from tubes might help with the seal. Drill a hole in the cap, and use some means to attach a tube – alternatives are proper plubming fixings, or another valve without a core – though IIRC I’m actually using a camelbak tubing joint! Zip ties are a good idea to get the tube to take the pressure. The one significant expense is a plumbers valve which goes between the first section of tubing and a second, then you top off with a track pump chuck of some sort.
Pump bottle up to 100psi, put chuck on tubeless valve, open valve. Might help to remove the valve core from the tubeless valve for first seating – works better with a compressor like this than a track pump as there is no blowback. Do remember to follow the normal procedure with soapy water etc.
I’ll try and take some piccys tonight.
Oh, and as I said before, no sueing me!
