OK…genesis Vagabond, shimano 10sp MTB groupset 11-36 MTB cassette
got some Pro-lite disc wheels …700c / road CX
will the cassette fit as essentially its a road hub ..right ?
actually i have fitted it and the only issue is the hub is 11speed but has a additional spacer for use with 10 speed
sorted ? well not quite as when i use the spacer ( think its 2mm ) the cassette lock ring will not do up or engage with the threads ( just spins ) if i take the spacer off there is too much play
i have used a thinner spacer ( comes with Shimano road cassettes ) but question is the road free hub shallower than an MTB hub which is why the lock ring won’t work with
