We’ve moved the kitchen from one room to another and now want to have the old kitchen as a breakfast type room with french doors.
The window we want to replace is 5ft wide so I’m assuming (it’s a 30’s house) there’s a lintle above.
As far as I can see the job will involve;
1) removing old window.
2) cutting down through render and brickwork to floor level
3) fitting frame and doors
4) making good inside and out
5) enjoying a cup of tea looking out through the new egress.
Questions;
1) do I need building regs for this work?
2) any rules on type of insulation etc new doors have to have (I’m assuming toughened/laminated glass is a given)
3) cutting through the wall – 230mm angle grinder with a diamond disk good enough or rent a 305mm one?
any other advice?
