I’ve just bled my wife’s Hope Mini Monos as per Hope’s video on their website.
It seemed to go well and the brakes feel much better. However, there seems to be a very slight leak when you squeeze and hold the break lever. It’s appears to be coming from between the reservoir cap and the reservoir, on the edge closest to the handle bars, although there’s no visible damage to the edge of the cap or the reservoir.
Is it just a case of taking of the cap off, making sure the edges are clean, then topping up with fluid, putting the diaphragm down properly and the cap back on, or do I need to replace the diaphragm?
Thanks
