Yeah that whole ‘one time only’ thing about power links is daft. It defeats the entire point of having them. Also, the SRAM connectors are directional and if you don’t get it the right way around, you’ve basically shot your load with that power link and will need to remove it using a link extractor.
Tang, no they aren’t going at the connecting link (although I’ve kept hold of the connecting link from the Wipperman as they aren’t use once items).
Weirdly my latest chain snapped in such a way that I was left with two middle links rather than one middle and one outer, which you would have expected if one pin had gone. So the only conclusion I can draw is that I snapped two pins in the same link. It made it easier to connect though. Both the chains I had problems with were the stainless steel ones, so I guess there’s something about those that makes them weaker? Can’t think what though.
One other point to mention is that in an emergency, you can use a 9-speed powerlink to join a 10-speed chain. It works about 85% as well, which if you’re 20 miles from the car on the edge of the Anza Borego Desert in middle of no where San Diego, is a real life saver.
