Already wasted one length of Ogee skirting……..
Anyone have tips on fitting and mitreing skirting boards?
First off Im trying to match up to old oak Ogee section boards. B and Q only had Ogee of suffcient height in pine and the dimensions are slightly different, being slightly thinner by about 3mm and sligthly higher by 5mm.I
m guessing the old stuff was imperial the new it`s metric equivalent.
The board wont lay flat, partly due to slight warping in the board and maybe because the newly plastered wall isn
t flat or perhaps a combination of the two.
The new plaster is a little thicker than the old which pushes the board out and so it`s proving hard to get the mitre cut right.
And the last problem is that the skirting needs to slot in behind the rad pipes and butt up against a cupboard and slot in to the existing mitres skirting the other,so theres not much tolerance.
It looks like it would be easier to fit it in 2 pieces
and hiding the joint behind the rad pipe………..
Thoughts?
