Advice needed - tak...
[Closed] Advice needed - taking a Reverb uppy/downy post on a plane?
[#3281437]
Hi all,
Is it necessary to let the air out of the post before flying or will it be ok as it is?
Posted : 25/10/2011 8:53 pm
Nope - old wives tale nor do you need to take air out of anything else. I have reverb and been abroad twice, I just slam it all the way down. The cargo hull is preasuired!
Posted : 25/10/2011 8:56 pm
Uses hydraulics anyway. Planes use hydraulics - go figure...
Posted : 25/10/2011 9:45 pm
Heather Bash - Member
True, but plane hydraulics are designed for use at high altitude whereas hydraulic seat posts are not......
Posted : 25/10/2011 10:33 pm
There's a slight increase in relative pressure when you put inflated stuff in the hold. When your fat arse lands on it from a botched tabletop there's a MASSIVE increase in pressure. It should handle the plane 🙂
Posted : 25/10/2011 11:53 pm
 Pook
depends if the plane is on a conveyor belt or not
Posted : 26/10/2011 6:14 am
