Adjustable travel Q...
[Closed] Adjustable travel QR's, where from?
[#1473839]
as title
The ones that go through the upper eyelet of the shock and slide though the linkage to alter the leverage ratio. Mines bent so need to find a new one from somewhere.
Anyone snapped an ets-x (silly question?) and still got the QR?
Posted : 02/04/2010 9:22 pm
Get in touch with a Rocky dealer, they will get you one through Silverfish.
Posted : 02/04/2010 9:24 pm
Having tried to get small bits out of siverfish before its a nightmare........
Shop says "we cant put in an order less than £XXX (around £300 last time I tried) so if you want the 50p washer you'll have to order the whole £300 crankset that goes with it"
Silverfish says "go to shop"
repeat add nauseum..............
Posted : 02/04/2010 9:28 pm
Think it depends on who you speak to a SF-was a mission to get some new pivot's for my Slayer SXC. Leave it with me-got a couple of mate's who work in bike shops who deal with SF regularly.
Posted : 02/04/2010 9:31 pm
I've moved since then I'll give the new LBS a try, might be luckier, was hoping someone might pop up in the STW fashion and either have a spare from a borked frame or be able to say that a seat clamp one or something else will fit the hole.
Posted : 02/04/2010 9:34 pm
Seat clamp might not be long enough but try a wheel Qr-if it fits through the holes you will be able to saw one down and wind a new thread onto it with a die. Got load's of old Qr's knocking about if you find they fit.
Posted : 02/04/2010 9:39 pm
