Viewing 14 posts - 1 through 14 (of 14 total)
  • A question for geometry lovers:
  • imnotverygood
    Triangle ABC
    Angle A is 100 deg
    Length AB = length AC
    Length BC = 5
    How long are AB/AC?
    Please show all you workings.
    binners
    Do I win a prize?
    nickjb
    imnotverygood
    Do I win a prize?
    Where are your workings?
    Or in this case, maybe not.
    nemesis
    Cut the triangle in half (to make two right angled triangles). It’s just SOHCAHTOA then 😉
    Cougar
    Take a midpoint of BC, call it D.
    Draw a line between A and D. We now have two right angled triangles, with an angle A/2 of 50 and a known Opposite of 2.5.
    Trig tells us SIN(angle) = O / H.
    So, H = O / SIN(angle)
    H = 2.5 / SIN(50)
    H = 3.26
    I think. It’s a quarter of a century since I last did that.
    imnotverygood
    Cougar wins!
    Thank you……
    Assuming he’s right of course.
    Cougar
    It feels about right.
    The 100′ angle will give you slightly shorter sides than if it were a 90′ angle. If it were 90′ then you could use Pythagoras’ Theorymajig.
    [AB]^2 + [AC]^2 = [BC]^2
    As AB and AC are the same,
    [BC]^2 = 2([AB]^2)
    [AB]^2 = [BC]^2 / 2
    [AB] = SQRT(25/2)
    (ie, square the hypotenuse, divide by two, and square root it)
    Which gives us a side of 3.53 – nominally longer than the 3.26 for the 100′ angle, as predicted.
    gonefishin
    Yeah 3.26 is correct but there is no need to mess about with pythagoras. The internal angles are 100, 40, 40 and you know one length so it’s just a matter of applying the sine rule.
    nickjb
    Is there a second prize for getting the answer first?
    nemesis
    Is there a prize for being first to provide instructions but not actually doing the workings for the lazy OP? 🙂
    dangeourbrain
    Cougar is correct.
    Cougar
    Oh, I know, I was just doing it as a half-proof to see if I was in the right ballpark. Last time I did trig was at school so I wasn’t sure I’d remembered it correctly.
    maxtorque
    It’s got something to do with pie right? It’s always about the Pie!
The topic ‘A question for geometry lovers:’ is closed to new replies.
