I’m usually fine shortening hoses and bleeding brakes, but had trouble with my new X2s last night.
I’ve got a set of fairly new Park cable cutters, but they kept fraying the ends of the braided hose making it hard to get the olive on. Do I need to use something different to cut the hose, a bigger olive (5mm or 6mm) or is it ok to snap the olive in half and then crip around the hose?
When I’d finished, I was surprised how spongey both brakes felt, maybe my bleeding was rubbish? Are the Hope Bleed kits worth buying, and what diameter plastic tube do I need to attach to the bleed nipple (I used an old piece of tubing, too short), I’ll need to get a longer piece from ebay.
And, finally, the video on the Hope tech says that centering the pads is even more important, which isnt something I normally bother with.
cheers
