These refer to Pike air u-turns btw:
1) What does it mean if when returning to full extension there is a quiet bang/knock?
2) When there is say 10-20psi more in the lower (-ve) chamber should this reduce availible travel? by say 20mm?
3) when there is more psi in the upper (+ve) chamber should this reduce availible travel?
4)Should oil leak out of the valves during pumping up/down of the chambers? is it just a case of turning them skywards when adjusting?
5) With forks locked out and brake on, when rocking forwards/backwards there is movement felt. checked and tightened headset/brake, bushings gone?
6) the number eg 05 stamped beneath the crown refers to year of birth?
Thank you for your time
