Now this is a bit of a head scratcher. I’ll start from the beginning:
So my crank shaft sensor went. That, and the Lambda(?) sensor were replaced but when they were done we found that the ecu had gone. That was rebuilt by the ECUdoctor.com and everything was put back together, this was done just before i went to Thailand for 2 weeks so by the time i got back the car hadn’t been used for 4 weeks. When i got back the battery was gone, so it was replaced with a new one.
So now the car works, but every morning without fail the car takes ages (30/40secs) of turning over to fire. To me it seems like there’s a drain of the battery over night which is where the struggle comes from (i’ve checked the earth/internal lights etc), it does eventually fire but it takes a while. It’s been back to the garage and they’ve changed the plugs/coils, but it’s not solved the problem. now they’re telling me they want to change the cambelt as they think that can be the only cause. It’s obviously not, how can it be the cambelt if it only struggles to start first thing in the morning?
Anyone have any ideas?
