XT m8100 brake leve...
[Closed] XT m8100 brake lever compatible with all shimano calipers?
As per title, can i fit say a deore 2 pot caliper to it. its for a DJ bike , so don't really need MOAR POWER but wondering if it will work
thanks in advance
Posted : 30/03/2021 11:19 am
Should be, the M8100 lever is used on both the 2 pot and 4 pot XT calipers.
Posted : 30/03/2021 11:49 am
YES ... its the hoses that change...
So its directly interchangable with any BH90 and easily hackable for BH59
If you mix BH59 and BH90 you need to hack one end... if its BH90 to BH90 it just needs connecting (olive and spike) that comes with the levers
Posted : 30/03/2021 11:56 am
AFAIK, all Shimano levers and calipers are compatible, provided you can get hose fittings for each end, as stevextc said.
Posted : 30/03/2021 12:06 pm
Forgot to mention it depends what series Deore (from memory) if they are BH59 or BH90
Posted : 30/03/2021 12:19 pm
ok great thanks all
Posted : 30/03/2021 1:32 pm
if the hose is BH90 then use a silver insert
if the hose is BH59 then use a gold insert
the olives are the same for both, as the external diameter of the two hoses are the same.
Posted : 30/03/2021 1:50 pm
hej how about this one ?  it says it is for mtb... deore apparently
https://www.chainreactioncycles.com/shimano-mt410-deore-post-mount-brake-caliper/rp-prod198902
Posted : 31/03/2021 9:04 am
hej how about this one ? it says it is for mtb… deore apparently
Yep, its BH59 though so you'd need a BH59 hose (the ones without Banjo) at that end.
If your planning to buy then I'd just get a BH90 one TBH.
€22.68 and €9.99 shipping to Sweden.. (if I remember) but if you need anything else the shipping cost is less important.
https://www.bike-discount.de/en/buy/shimano-slx-br-m7100-post-mount-g03s-brake-caliper-847199
Posted : 31/03/2021 10:07 am
fantastic info @paton and thansk @stevextc and @reggiegasket
Posted : 31/03/2021 1:41 pm
