Home Forums Bike Forum X-Fusion Trace travel adjust
Viewing 13 posts - 1 through 13 (of 13 total)
  • X-Fusion Trace travel adjust
  • tootallpaul
    Morning.
    I’m interested in getting a pair of X-Fusion Trace’s for my Solaris- anyone know easy it is to adjust the travel down from 140mm to 120mm?
    Cheers,
    Paul
    bungalistic
    When I got my Slant forks from 18bikes they did the travel adjust for me before sending them out. I believe it’s not a difficult job if you’re happy messing about inside a fork
    tootallpaul
    Cool – will see of 18 bikes have them in stock.
    Just watched the video, and there is a couple of specialist tools required.
    austy
    When I got my metrics they were adjusted by upgrade cycles before they got to freeborn cycles.
    tootallpaul
    Cheers Austy- I’ve dropped them a line too.
    jimplops
    My traces have an adjuster on the left leg, twist and it locks it at 120mm.
    tootallpaul
    Cheers Jim – are they the 2015 model?
    jimplops
    2014 from crc, we’re just short of half price.
    tootallpaul
    So. Is it worth the extra cash to get the 2015’s?
    Ponders…
    tootallpaul
    Crumbled and went with the 2014’s from CRC.
    NormalMan
    If the adjustment is the same as Velvet’s then I have a pdf of how to do that I can email you if you like.
    tootallpaul
    No need NormalMan- the 2014’s are 120mm.
    NormalMan
    Ok cool. I had it as it I’m told it’s the same for the Slides on my solaris.
    Currently at 100mm but tempted to try then at 120 in the future.
The topic ‘X-Fusion Trace travel adjust’ is closed to new replies.
