Home › Forums › Bike Forum › Would you not buy a shimano cup and cone hubbed wheelset…
- This topic has 71 replies, 51 voices, and was last updated 11 years ago by swingbing.
_tom_Free Member
Why are people saying Hope cartridge bearings dont wear out – do you ever ride in the wet or just sit on your turbo trainers
Had well over a year on my current front ones and rear haven’t been changed since I bought it 2nd hand a year or 2 ago. Been riding in all sorts of weathers and a summer/wet autumn of Whistler where it got more use than a year of UK riding for me.
bigyinnFree MemberStainypants – Member
in the ye old days around here with rim brakes your rims would last near the life of a cup and cone hub
Err not where I used to live. A year out of a rim would be a result.binnersFull MemberServicing cone bearings maybe a faff but replacing cartridge bearings is no cake walk – especially the rear which is a huge faff.
1. Once, every other year, drop wheel in LBS
2. Pick wheel up from LBS the following day, with lovely smooth new bearings
3. Ignore for 2 years
4. Repeatits an effing nightmare!!!! 😉
StainypantsFull Memberin the ye old days around here with rim brakes your rims would last no where near the life of a cup and cone hub but now we all disc brakes the hubs are now the weakest link, i’ve trashed a few hubs i’m not the best at looking after stuff had no problem with hope ones
ClongFree MemberIf i recall correctly, you can replace the cups in shimano hubs, its not easy mind.
I’ve used both, well sealed cup and cone last ages. I have a set of deore hubs that still spin smoothly despite riding through flood water that was deeper than the wheels some 10 years ago. I’ve not used much in that time though.
That being said, the hope XC hubs on the commuter bikes are getting on for 7 years old, around 35,000 miles. I’ve had one of the rear bearings seize in that time. Wore out a set of pawls though, and the freehub body is looking a bit rough around the seal area.
King hubs seem to be a mix of both, you can adjust the play out of them via a cone set up, but if the bearings do fail you can replace the cartridge entirely.
birney29Free MemberI have a 5 year old set of M475 shimano hubs on my wheels. These are the most basic ones shimano made.
5 years of riding in all weathers and they have lasted well. I have changed the bearings twice. 10 minutes per wheel and jobs-a-good-un.
Getting a set of XT wheels on the new bike – not because I dislike cartridge bearings, but because i have had so many years of trouble free biking on Shimano wheels.
ndthorntonFree Member1. Once, every other year, drop wheel in LBS
4. Repeat5. Once every year ride bike
NobbyFull MemberGot a 5/6 year old set of XT/819’s on my winter hardtail – they’ve been ‘serviced’ once in that time & still run smooth. Not sure if the newer stuff is less reliable but not seen/heard any horror stories with them recently.
johnellisonFree Member…but replacing cartridge bearings is no cake walk – especially the rear which is a huge faff.
If you’re a ham-fisted bungling neanderthal, maybe. I can replace a full set of rear bearings on a Pro2 in 15 minutes, if I take my time. If I’m in a rush I can do it in 10.
And I don’t need cone spanners or any other special tools – a plastic hammer, a 6mm pin-punch and a selection of old sockets is all that’s needed.
johnellisonFree MemberOr two months in the case of my new Superstar wheels. Now I have to spend money on new set (not cheap if I want decent bearings). If I still had cup and cone, I’d just put some grease in and tighten them up – takes what, 15 minutes? My Hopes go through at least a set a year too, probably more.
If you buy bearings from a bike shop or from Superstar you will pay over the odds. Go to a proper bearing supplier (take the old ones with you if don’t know what size they are) and you’ll pay under £20 for a full front and rear set. Insist on quality items such as SKF, Toyo or NSK, not cheap Chinese/Indian/Iraqi/Yorkshire copies.
The problem with cartridge bearings is that NOBODY uses the correct type in hubs – everyone uses deep groove radial bearings which are fine for rotating loads but not for side-loading. The correct type should be angular contact, or even taper roller, but the latter two types are expensive and require some form of preloading. Not easy in the restrictive space around a bike frame/fork.
buzz-lightyearFree MemberAlways had problems keeping them at the proper tension and when they get loose it damages the cone surface which ruins the hub. You can wreck cartridge bearings without worrying about the hub.
richmtbFull MemberI’ve used both.
Hope XC and Hope ProII
and
Shimano XT.
I’ve replaced cartridge bearings in my hope hubs. Its not as straightforward as just undoing the cups and squirting in some new grease but you don’t have to do it as often.
I really don’t have a preference
mrmonkfingerFree MemberWhat about that, a range of good and bad experiences with both bearing types!
As for the opening question, no I would most certainly not buy them.
Out of all the wheels I’ve owned, the only hubs that have been trashed have been Shimano. A motley collection of dead freehubs (several), irreplaceable pitted cups, and hubs that from new have come with loose locknuts which wind up and trash the bearings (two, one knackering a particularly nice set of XT road wheels). Oh, and they seem to weigh half a ton.
So I have either sold them and/or replaced dead ones with cartridge hubs.
So far:
number of problems with exploding hope flanges: 0
number of problems with cartridge bearing lifespan: 0
number of problems with worn out pawls: 0The sum total of the cartridge hub servicing has been on my wife’s Xero XR1, on her roadie since 2006, they have > 10k miles on and so far have had 1 new set of bearings. Oh, and my hopes are due a bit of regreasing.
The humanity!
NorthwindFull Memberbinners – Member
2. Pick wheel up from LBS the following day, with lovely smooth new bearingsI’ve stood in my LBS waiting to be served for longer than it takes to service either an XT or a Pro 2 hub. Your way sounds **** regardless of your choice of hubs.
OTOH, the only way I could get 2 years out of a set of bearings would be to ride about 1/6th as much as I do so I’ll not be doing that either 😉
woodlikesbeerFree MemberI’ve got fed up with cup and cone. Inevitably a cone gets pitted so you decide to replace it. However, the cost of most Shimano cones is not far off the price of a new hub. It doesn’t make sense. Unless you religiously remember to overhaul your hubs every few months you’ll end up with worn cones. Although I’ve never a problem with the cups going on a Shimano hub.
Cartridge for me from now on. Especially as they much easier to replace IMO. Don’t both by the genuine spares. Measure the bearing and then order off from an online bearing shop (or eBay which is often cheaper for the P&P).
tthewFull MemberI know it was 7 hrs ago, and a load of posts, but,
I sometimes get less than a month before I have lots of play and a rough feel.
I’d wager you are installing them wrong ndthornton. Do you press them in by tapping or pressing the inner race somehow? If so you’ll be knackering the faces of the races on installation.
FOGFull Memberi just couldn’t bring myself to take either c&c or cartridge hubs to a bike shop for a fettling. While i am sure there are plenty of top class mechanics in our bike shops I have encountered a few whose skills were considerably less than my own non too impressive skills.
fourbangerFree Membermtbfix – Member
My XT rear wheel is borked. Cone took it upon itself to tighten hard against the bearings,Chortle. Do you own cone spanners?
BezFull MemberI wouldn’t use anything but Shimano cup-and-cone hubs.
IME, overhauling the bearings takes 15-30 minutes and needs doing maybe once every 12-18 months at most. I’ve never actually managed to come even close to killing one at LX/105 level or above, and I’ve used some for over 10 years. They just keep going.
thisisnotaspoonFree MemberHowever, the cost of most Shimano cones is not far off the price of a new hub.
Que?
The cone’s are a couple of quid! The balls are pennies! In fact you can buy an entire XT rear hub for less than you’d pay for half decent bearings for a pro2!
stumpy01Full MemberHmmm. The wheels that came with my 01 Stumpy FSR have got WTB cup & cone hubs.
They’ve never been serviced. The rear hub is pretty grumbly, but they both still work fine. I have thought about servicing them for the last few yrs but reckon it would be terminal if I did so have just left them.
i had a spoke replaced on the rear a few weeks ago and got the bad news that the rim has split(along the internal surface you stick the rim tape to), so I’ll be retiring that wheel because of the rim, not the hub.
If the hubs on my new(er) FSR last that long, I’ll be pleased. Although I will probably service them at some point….neilsonwheelsFree Member8000+ road miles on cup and cone bearings last year and they are still as tight as the day they were purchased. I will service them before they go back on for the warmer weather.
nickcFull MemberThing I’ve learned with shimano cup and cone is there isn’t enough grease in them from the factory. When you buy new, open them up, splurge the world’s supply of grease in there and close. Leave alone for the rest of your life.
I’ve got Shimano, Hope and a GI front hub, the only one that gives me ‘some’ trouble is the Hope XC rear…pawls, bearings that wouldn’t come out, trashed freehub, but that’s over 4-5 years or so.
woodlikesbeerFree MemberQue?
Where from? I’ve never been able to find a supply at a sensible price. Any links very much appreciated.
caspianFree Memberonly issue with them is if your a “its making no noise its fine” kind of rider. they need preventitive maintainance.
by the time you hear the issue – its too late.
Which in my case was ten miles into the Kielder 100. In retrospect this was a good thing as my Avid brakes shat the bed around the same time.
binnersFull MemberI’ve stood in my LBS waiting to be served for longer than it takes to service either an XT or a Pro 2 hub. Your way sounds **** regardless of your choice of hubs.
Sounds like the problem isn’t hubs or bearings, but a **** LBS. My LBS is great. Which is just as well because I’ve the mechanical aptitude of an orangutan with learning difficulties. Hence my loathing of the medieval technology involved in Shimano hubs. They really are ****!! I like riding my bikes. I do it a lot. I don’t however like fannying around with them after every ride. So there! 😛
birney29Free MemberBinners,
most of the posts in favour of cup and cone state that the maintenance is minimal – perhaps even less than that of cartridge hubs.
If you need to fanny around with them after every ride, the problem is you – not the hub.
BezFull Member“the medieval technology involved in Shimano hubs. They really are ****!!“
It is, of course, only the same technology that’s in the cartridge bearing.
It’s just that cones are designed for people are happy operating spanners, whereas cartridges are designed for people who prefer to hit things with hammers. No great shame in that, but it’s disingenuous to claim that cups and cones are somehow inferior or obsolete.
MrSalmonFree MemberI wouldn’t not buy them, in that I wouldn’t go out of my way to avoid them, but all things being equal I’d probably go for cartridge ones first.
thisisnotaspoonFree MemberWhere from? I’ve never been able to find a supply at a sensible price. Any links very much appreciated.
I had Mercian cycles as my LBS, they just took them out of a little box of them. But they are an old skool LBS and are better known for making some rather nice steel frames (including for Paul Smith!)
Google is your friend though, £3 each for the cones. Whole hubs for £10 front, £25 rear.
http://www.google.co.uk/#hl=en&tbs=p_ord:p&tbm=shop&sclient=psy-ab&q=shimano+xt+hub+rear&oq=shimano+xt+hub+rear&gs_l=serp.3…8468.9749.2.9812.5.5.0.0.0.1.360.735.0j3j0j1.4.0…0.0…1c.1.eEU5slldvZc&pbx=1&bav=on.2,or.r_gc.r_pw.r_qf.&bvm=bv.41018144,d.d2k&fp=2295338f0a6c996f&biw=833&bih=544you can swap the internals betweend eore and XT hubs, as long as you use the right spacers as one freehub has the bearign further outboard than the other.
From a mechanical perspective C&C wins hands down as it can take axial loads, a radial cartrige bearing (as used in most hubs) takes radial loads, their axial rating is much much lower, angular contact bearings (like you get in headsets) would be better, but aren’t as common. Cartriges advantage is in the seals and their disposable nature.
swingbingFree MemberApologies if this has been discussed as I’ve only skim read this thread but…
Sealed bearings in my limited experience (pro2 evo’s) do not roll as well as cup and cone. I think if I were building an XC race bike I’d consider cup and cone for this reason.
The topic ‘Would you not buy a shimano cup and cone hubbed wheelset…’ is closed to new replies.
