Where to get plasti...
[Closed] Where to get plastic tubing for bleeding Hope brakes?
Or is it worth getting the proper bleed kit?
Ta
Posted : 03/12/2009 12:40 pm
halfords - windscreen washer pipe
Posted : 03/12/2009 12:41 pm
Nahh, you don't need a kit. Hopes are the easiest brakes in the world to bleed.
Any old tubing will do. Maplin? Aquarium shop?
Posted : 03/12/2009 12:42 pm
 DT78
Got mine from B&Q. cost pence.
Posted : 03/12/2009 12:43 pm
Win - there's a Halfords just down the road.
Thanks folks.
Posted : 03/12/2009 12:44 pm
But how do you get it to stay on the nipple? Keeps falling off, especially when wet.
brewers supplies are a good bet too. Never used more than cheap plastic pipe and a jam jar to bleed brakes before and I'm proud to say my bike shop commented on the "good bleed" on my Hopes
Posted : 03/12/2009 12:45 pm
it's the wrong size then
On the slim chance this is not a wind-up ๐Ÿ˜€ you could try using a smaller diameter tube?
(have I just been "had"?)
Posted : 03/12/2009 12:46 pm
I think there's a good chance! ๐Ÿ˜‰
Posted : 03/12/2009 12:48 pm
No, serious question. My tube just won't stay in place. always falls off, and the end gets knackered with keep pushing it back on, so I cut it, and shorten it then it gets knackered again, so I cut it.......
Posted : 03/12/2009 12:50 pm
zip tie?
Posted : 03/12/2009 12:52 pm
I dismantled a hand wash pump thing to get a bit of pipe when my brake exploded a couple of weeks ago on a weekend away.
Posted : 03/12/2009 12:54 pm
B&Q have reels of different diameter plastic tubing. Easy. Even for Sir Neil. ๐Ÿ™‚
Posted : 03/12/2009 1:01 pm
 sv
Tubing attached to a syringe and do it 'bottom up' - as it were ๐Ÿ˜†
Posted : 03/12/2009 1:05 pm
maybe your tube isn't flexible enough. It is a problem I have never encountered with the brewers tubing I use
Posted : 03/12/2009 1:08 pm
 D0NK
+1
5minute job, 2 minutes if you get someone else to draw excess fluid from the lever reservoir at the same time.
Posted : 03/12/2009 1:12 pm
have a good length of the piping (so the fluid doesnt reach the end during bleeding) and cable tie it to tubing so that the natural coil of the piping sits nicely on the nipple
+1 for halfords
if you cant find the right size by smaller thank you need, get a lighter/heat- heat it up and push it on the nipple, will shrink to the right size
Posted : 03/12/2009 1:17 pm
