Foamists… I need advice.
I want to make a float for swimming, it’ll fit in between my legs (it’s called a pull buoy) and provide buoyancy. You can buy these already (and I have many) but I want to make a custom one for swim-run races where you’re in and out of the water lots and need large amounts of buoyancy to counteract the drag/weight of swimming in trainers.
So, what foam? It needs to be:
1) low density, for high buoyancy and low weight for running with.
2) hard-wearing, it’ll have holes for elastic to hold it to my leg while I’m running, I don’t want the elastic pulling through or bits of foam falling off into the lake/sea/environment.
3) easily cut/shaped so I can create the perfect balance of size and comfort (!)
4) easily glued or otherwoth stuck to itself (so I can create a good shape with different bits)
5) cheap!
Any tips and online sources? Thanks.
