- This topic has 66 replies, 26 voices, and was last updated 7 years ago by molgrips.
Weight loss
molgripsFree Member
“It’s not a clear-cut relationship between calories and weight loss”
– Glenn Gaesser, professor of exercise science at Arizona State University
fifeandyFree MemberA bit of an unfortunate quote taken a bit out of context compared to the point being made through the article.
However, until someone finds a way around physics and can create energy from nothing then the relationship is indeed quite simple.
zilog6128Full MemberAnyone who think the way the human body works is “simple” must be a bit simple themselves 🙂
FrankensteinFree MemberThere are other factors too but the most measurable is a deficit in energy metabolism.
weeksyFull MemberWell, it seems quite simple to me…
I’ve exercised, dieted and whatever sort of half-arsed for a while.
Recently i’ve more than doubled my cycling miles along with the Horizon 5-2 at the same time… in 4 weeks i’ve dropped 9lb of weight…
Whilst it’s not as simple always as ‘eat less move more’…. sometimes it is actually exactly that simple.
molgripsFree MemberA bit of an unfortunate quote taken a bit out of context compared to the point being made through the article.
Really? How so?
Only if you assume everything going into your mouth is converted perfectly into a single form of energy, and the unused part of that energy is perfectly stored as fat. Except that’s not the case.
Are you going to disagree with the professor?
molgripsFree MemberAre you just trouble-causing?!
Partly, but I got the piss taken endlessly for saying calories in vs calories out wasn’t the whole story – and yet here is a professor of exercise science saying the same thing. So come on then, take the piss out of him too. I’m sure he’d love to hear your expertise. Maybe you could write a paper, we’d love to read it.
Rubber_BuccaneerFull MemberFar too inflammatory for me, I’m off to TJ’s poppy thread 🙂
ghostlymachineFree MemberSo, professor whose entire existence is dependent on making these things as complex as possible publishes paper making out that these things are really really complicated.
What a surprise.
LeeWFull MemberPartly, but I got the piss taken endlessly for saying calories in vs calories out wasn’t the whole story – and yet here is a professor of exercise science saying the same thing. So come on then, take the piss out of him too. I’m sure he’d love to hear your expertise. Maybe you could write a paper, we’d love to read it.
*Hugs*
fifeandyFree MemberReally? How so?
If you read the article, what it is explaining is that performing exercise has various other impacts other than the calories burnt during the exercise.
As pointed out in the article, you may be less active during the rest of the day after exercise, or you may crave (and consume) more calorie dense food.So the quote should have been:
It’s not a clear-cut relationship between calories burnt during exercise and weight loss
A subtle difference yes, but quite a different meaning.Only if you assume everything going into your mouth is converted perfectly into a single form of energy, and the unused part of that energy is perfectly stored as fat. Except that’s not the case.
No, we don’t need to make that assumption at all.
We only need to say, if you put less energy in your mouth than you burn in a day, you WILL lose a corresponding amount of mass, be that from water/fat/glycogen/muscle tissue.
It is indeed very simple as there is no-where else for energy to come from, and you can’t make energy from nothing.nickcFull MemberFrom that same article:
But overall, science still indicates that if you want to lose weight, running is one of the better option as it uses a lot of big-muscle groups, key for calorie burning.
The details can get quite complex, but at the same time, as Weeksy up there points out, it’s mostly pretty straight-forward.
molgripsFree MemberWe only need to say, if you put less energy in your mouth than you burn in a day, you WILL lose a corresponding amount of mass
That’s not true.
How do you think fat actually gets laid down? It’s the cells responing to certain hormones and stimuli in the blood. If those stimuli aren’t there then the fat cells won’t convert the glycogen into fat and store it.
No, but you can eke out the same amount of energy, and you can also shit energy out of your arse or radiate it from your skin. It doesn’t have to go into your fat cells.
I did read the article by the way, I also read some ofthe abstracts of the papers linked to in the text.
To me the article says that there are regulatory mechanisms that tend to maintain weight. Like this one:
Changes take place within the body’s tissue that reduce resting metabolic rate, especially during sleep, and as weight decreases, you burn calories less efficiently the next time you exercise. This seems to be particularly the case if a runner cuts their calorific intake at the same time as embarking on a new exercise regime.
Which backs up what I’ve learned. That *SOMETIMES*, if you eat less and move more, your body compensates through the mechanisms at its disposal and you don’t actually lose much if any weight.
I’ll re-iterate. It is calories in vs calories out. BUT – calories out is a compound term made up of many many different factors, not just how much work you do when you exercise. And it’s affected by the nature and even timing of those calories in. So it’s not simple.
YES BUT NOT ALWAYS!
fasthaggisFull MemberAre you just trouble-causing?!
He was just jealous of all the attention TJ was getting on his poopy thread. 😛
nickcFull MemberThat article says, losing weight is hard as you’re body resists it (homoeostasis), but one of the best ways to do it is running.
You can argue over the details, but that’s the message.
ghostlymachineFree Memberyou burn calories less efficiently the next time you exercise.
Needs to clarify his understanding of efficiency, or use of the language. You are technically burning them more efficiently. You use less to do the same work.
FunkyDuncFree MemberI’m not a professor…however
When I sit on my arse eating pies and cake I get fat.
When I exercise more and eat better food I loose weight.
Who’d of thought it ?!? 😯
fifeandyFree MemberThat’s not true.
You just contradicted yourself and claimed you have a magical way to create energy. You should harness it and form an electricity company, you could become a rich man.
And whoever said weight loss was only about fat cells?
If you don’t think the body (everything it does) is fuelled by turning mass into energy then go ahead and explain where the energy is going to come from to meet the shortfall.Lets make it very simple – if the body requires Xkcal per day, even after various changes to metabolism to protect itself. If we then feed it X minus 250kcal, then we have a shortfall of 1046700 joules of energy for the day. If it doesn’t come from a loss of body mass, where do you propose it comes from?
zilog6128Full Memberbut one of the best ways to do it is running.
I’d say running was a terrible way to lose weight, based on the number of posts on here about people taking it up then getting injured!
ghostlymachineFree MemberRunning is good for losing weight.
It’s terrible for injuries.
So you can lose a few kilos, then put them all back on when you knacker your ankle.FunkyDuncFree MemberRunning is good for losing weight.
It’s terrible for injuries.No, it is no worse than any other sport. What happens is that people who get in to it tend to push them self harder than they should and then get injured.
johnnersFree MemberIf you don’t think the body (everything it does) is fuelled by turning mass into energy then go ahead and explain where the energy is going to come from to meet the shortfall.
Your body doesn’t turn mass into energy, unless you’ve some nuclear reaction going on.
molgripsFree MemberIf you don’t think the body (everything it does) is fuelled by turning mass into energy then go ahead and explain where the energy is going to come from to meet the shortfall.
One mechanism is in the article. Your body could lower it’s BMR.
From a lower BMR tomorrow.
I think he means you burn them less easily. In other words (another mechanism for retaining energy) your body makes less energy available to you. So you fatigue quicker, and you can’t burn as much energy. You know how when your laptop battery gets down to 20% and it goes into energy saving mode? Like that.
You don’t need to spell out the maths for your simple heat engine model. I have a degree in Physics.
What I’m saying (and so is the prof) is that your simple model is inadequate for the real world.
fifeandyFree MemberYour body doesn’t turn mass into energy, unless you’ve some nuclear reaction going on.
i think you’ll find it does. or have you also found a way to magically create energy?
You can’t lower BMR indefinitely, and even if you could, you could still just go out and exercise beyond your intake.
No-one will argue that the body will adapt to try to preserve its weight – it still cant make energy though.molgripsFree MemberYou can’t lower BMR indefinitely, and even if you could, you could still just go out and exercise beyond your intake.
It gets harder and harder though, clearly. Otherwise you’d be able to keep exercising and eventually disappear altogether. So there’s a point beyond which you won’t be able to push yourself.
No, but it can preserve what it has, and force you to either eat more or stop working so hard. WHICH IS WHAT THE ARTICLE SAYS. And what I’ve been saying for years. You have actually agreed with me by saying the body adapts to preserve its weight. That’s been and still is my point.
fifeandyFree MemberWell, it doesn’t so much force you to eat more or stop, it just tries to steer you in that direction. That’s where a bit of willpower is required. Calories in/out still applies, it just becomes progressively more difficult both physically and mentally to keep it in defecit. If the body was capable of breaking that relationship then people wouldn’t starve to death.
So overall, fairly complicated underlying biology governed by a very simple rule.
BigJohnFull MemberAll I know is that if, Monday to Friday, I avoid all cereal-based foods (bread, pasta, rice and, er, cereals), fruit and dairy then I don’t feel hungry, I have plenty of energy and as a bonus I lose a bit of weight.
Of course I’m consuming fewer calories but the reason is that I don’t get those irresistible urges to to have a kit-kat or a big lunch which seem to be consequences of eating stuff that gives you a blood-sugar hit. It doesn’t make me feel like I’m missing stuff, but it’s a lot harder than just grabbing a piece of toast or a sandwich.
I just checked on iDave’s Facebook but he doesn’t seem to have picked up on this research yet. He did mention this though:
“The word ‘triathlon’ comes from the ancient Greek ???????, meaning ‘mid-life crisis’.”
RobHiltonFree MemberRunning is good for losing weight.
It’s terrible for injuries.Rubbish! It’s great for picking up injuries – I’ve shagged my knees doing it 😆
Crashing bikes is also pretty decent for it too.
sbobFree MemberNo, but it can preserve what it has, and force you to either *eat more or **stop working so hard. WHICH IS WHAT THE ARTICLE SAYS. And what I’ve been saying for years. You have actually agreed with me by saying the body adapts to preserve its weight. That’s been and still is my point.
*Calories in.
**Calories out.
Shittest.
Troll.
Evar.One can only assume it’s your time of the month and you were overtaken by a Tory.
FrankensteinFree MemberDon’t let your body adapt.
I’m off for 2 protein shakes.
I also have a gap of 400 kcal yay going to have 2 ice creams.
Dropped 25kg but still have 12kg to go.
Good sleep (leptin??) and keeping busy stops my pangs.
FeeFooFree MemberThe important point is that calories in/calories out model for humans is entirely correct over a long period of time.
The body compensates by making it harder to lose weight but it cannot compensate against willpower.
If you stopped eating, in time you would die. Why? Because the body can’t compensate to that level.Extrapolate that to cutting your calories to a level less than your body needs to maintain weight and you will lose weight.
It may take time, but it will work.footflapsFull MemberAnyone who think the way the human body works is “simple” must be a bit simple themselves
+1
Also, anyone who thinks it is an open loop system is also a bit simple….
molgripsFree MemberTwo summers ago I was eating nothing for breakfast, meat and veg for lunch and low gi for dinner. On the way to work I rode a brisk 40 mins and on the way back it was 90 mins of smashed singletrack at Swindle, as hard as I could. I remained 91kg, but my legs ached badly and I didn’t recover.
Now I do less and eat more, including more junk, I’m 87kg.
That summer I didn’t eat enough, so my body didn’t rebuild and recover much. It cut back on expenditure, it became too efficient.
Our bodies are complex feedback systems, and different stimuli affect the system and make it do different things. And there are constraints placed upon us by our daily lives and the fact we want to be cyclists.
I think that the more of a shock something is, the further from the norm it is, the less your body can adapt so you lose weight. I’ve been trying to diet for years and falling off the wagon a lot, and I’ve been riding my whole adult life. The only time it’s worked well is when I’ve done something very different. But crucially, each time I get back on the wagon it’s less and less effective. 17pc body fat by the way before you accuse me of being a lazy porker.
BigJohnFull MemberYou’ve been dieting Moly? I thought you knew better than that.
There’es only one real diet. The Yo-Yo Diet. Guaranteed to give you an extra 3Kg a year.
Diets make you fat.
The topic ‘Weight loss’ is closed to new replies.
