Mrs Q commented that my nose hair was too long yesterday and maybe I should cut it.
I’ve never cut it before, and was thankful to remember my beard trimmer had a nose hair attachment which tickled a lot.
How often should I trim my nose hair, and is it a bit like shaving your balls, in that if you do it once, you have to keep doing it because it itches so much?
Indeed. I always pluck mine during particularly stressful moments in rugby matches. My son tells me off.
I’ve also noticed I pluck my ear hairs when I’m stressed by driving. Better than picking bogies I suppose.
sad to say I ended up spending £12 on a decent pair of tweezers (missus kept hiding her’s when she found what I used them for), so that you don’t get any ‘misfires’ when pulling the buggers out.
I’m pretty sure your nostril hairs are just the other end of your eyebrow hairs (assessing length of plucked nostril hairs tends to confirm this).
If you pluck them, you will lose all your eyebrows.
I just give mine the occasional trim with one of those ‘old man hair trimmers’.
Screw plucking them, I just use a cheap circular-headed trimmer thing, no pain at all (never catches the skin etc.). Need to do it every couple of weeks but takes 5 minutes.
I was observing to my barber how he used to ask if I wanted “something for the weekend, sir?” whereas now it’s “shall I do your eyebrows and ears, too?”
OP – just start plucking. Give it a few years and you get past the crying stage.
Wasn’t there some myth going around a few years ago that plucking nose hair was bad for you, or some bacteria would get in the follicles or something?
In any case, nothing more irritating than when one gets a bit long and you can suddenly feel it just starting to curl under the septum, but it’s not long enough to yank out!
Only 27 here, not a particularly hairy person, but nose, ear and eyebrow trimming are insisted upon by the other half now……..
I currently use the pinch, breath in, breath out, relax, achieving a zen like start of relaxation before plucking them out sharply technique, however I used to have a circular trimmer electric thing on a shaver attachment. Anyway when that got lost in a house move I was tempted by a cheapy version of just the nose hair trimmer from some market stall whilst out window shopping with Mrs-g. Anyway, after a few minutes of me waxing lyrical about how amazing these nose hair trimmers are and how I used to have one we got home and I put a battery in and fired it up, its making that high pitched whirring sound as I insert it into nostril A, however, instead of the satistifying sound of hairs been chopped, instead I hear the slowing of the whirring sound that indicates that the cheapy thing I have just bought is not quite as high powered or sharp as it needs to be and is currently slowing down as it becomes entwined in still attached nose hairs. Mrs-g sees the panic in my eyes and immediately bursts into fits of laughter, while i slowly come to the realisation that there is only one way out of this situation and its going to hurt.
PSA for those with an inqusitive mind. Don’t try the “sniff a lighter flame” method. The hit of agonising pain is instant (and, strangely, felt in the back of the throat as well) and when you eventually stop sneezing (hours, not minutes), you’ll notice a browny/red liquid with little black charcoaly bits seeping from the affected nostril. I’m not sure what sort of primitive threat has led to the body to evolve by simultaneous eye watering and every sphincter snapping shut in unison the instant the flame touches nostril lining either, but you can look forward to that as well.
