For some weird reason i simply cannot get my pads to stop a *ting* on the brakes.
If i look carefully it looks to me like the bottom part of the pad isn’t quite touching the piston, but the part of the pad nearest the split pin is..
I’ve been trying to think of a way to resolve this and the only thing i can come up with is it’s cause by the spring clip on the pads, which is pushing the ends out as it’s more triangular at the point where the hole is, rather than being fully rounded, which i guess would give the pads better alignment ?
Can you get ‘better’ spring clips ? anyone else had this ?
They’re Shimano M615s if that helps, with the little arms down the side of the pads.
