This groupset? Why,...
[Closed] This groupset? Why, yes. Yes it is.
Gravel specific!
http://www.cyclingnews.com/news/shimano-grx-gravel-specific-groupset-launched/
Posted : 07/05/2019 4:05 pm
Hope they release an XTR equivalent groupset for gravel racing - they could call that one 'GRR'
Posted : 07/05/2019 4:09 pm
*Applause*
That aside, it actually looks pretty good, especially in 1x format. Some clever ideas.
Posted : 07/05/2019 4:11 pm
Uugh, the chainring bolts don't line up with the centre of the arms.
Posted : 07/05/2019 4:26 pm
And here's a nice on-brand link 🙂
grit.cx
Posted : 07/05/2019 5:40 pm
Glad to see 2x is still a “thing”..
Posted : 07/05/2019 7:08 pm
Uugh, the chainring bolts don’t line up with the centre of the arms.
Should they? Considering pedalling forces are mainly in one direction (clockwise) maybe that is sensible?
Posted : 07/05/2019 7:28 pm
Apologies, Chipps, hadn't seen that when I posted. *Doffs titfer*
Also...
Hydro cross top levers! Woop!
Posted : 07/05/2019 7:33 pm
I don't care as long I can find a way to afford it on one of those 3T aero gravel bikes.
Posted : 07/05/2019 7:59 pm
48/30? Hydro top brakes? Take my money.
Posted : 07/05/2019 8:05 pm
don't fit my MOAR AERO bars though
cranks
they 110mm 4 arm asymmetric bcd? like all the current road stuff? looks like it, will be harvesting some rings
Posted : 07/05/2019 8:37 pm
Well, there must be something different going on with the small ring if they've managed to fit a 30T in there.
Posted : 07/05/2019 8:40 pm
ah outer is still 110mm, inner is 80mm
Posted : 07/05/2019 8:42 pm
Like it.
+1
Got a V-Twin setup on mine at the moment but it makes the brakes feel quite wooden with the cable routing. The CX is in need of a total overhaul so that's suddenly gone top of the list. Will try and get it through this year's Three Peaks and then completely rebuild it.
Posted : 07/05/2019 8:44 pm
should have just made some "gravel" specific xtr/xt/deore cranksets and levers
Posted : 07/05/2019 8:55 pm
So they still have that crappy 96bcd arrangement which means you can't put anything smaller than 30t on without using the granny tabs, so swapping chainrings is a massive pain.
I'm wondering whether to jump ship to the golden sunlit uplands of SRAM goodness - this doesn't encourage me to stay in the foggy Shimano lowlands.
Posted : 07/05/2019 8:57 pm
So, do we think this will be cheaper than the equivalent Ultegra Di2?
Please say yes!!
Reserving any further interest until UK prices are known. Hopefully it will priced on par with the #asphalt equivalent groups in which case I could be tempted to hydraulicalize my RAG+
Posted : 07/05/2019 9:05 pm
So they still have that crappy 96bcd arrangement which means you can’t put anything smaller than 30t on without using the granny tabs, so swapping chainrings is a massive pain.
The small ring is on a new 80mm BCD so it supports 30T rings. Currently it's 32T minimum (unless you go for the Absolute Black 30T ring set).
Posted : 07/05/2019 9:45 pm
Any guesses on how much it will cost?
Posted : 07/05/2019 10:30 pm
UK retailers are listing GRX now. Consult the internets...
Posted : 10/05/2019 8:56 pm
