but a decent suspension linkage does.
No, chain growth at the top of the chainring to cassette is closely modelled and designed to give the correct pedalling and suspension characteristics under load the designer wants. But none will look at how much slack the mech has to take up or even what point in the travel it has to do this, as suspension curves are not linear.
This is because the load from the clutch is dependant on what gear you are in, how much chain is flapping about, how much tension you set it to, the position of the mech arm, how much resistance the clutch gives at different points (the highest resistance in the clutch is at the initial movement), etc.
Basically impossible to model well.
It will have an effect, but given 99% of people dont have a personally tuned shock (and I dont mean ticking ‘hucker’ box when posting it to TF), id say its probably not a worry.
