[Closed] supermarket diesel, whats wrong with it?
i started a thread a few days a go about the van conking out, it lost power a few times at certain revs and then just stopped and wouldn't start, it had bubbles in the fuel line, anyway had the rac out today and he managed to get it started. he tried it with easy start and nothing happened, then he just pumped a lot of fuel through with the plunger thingy and kept on turning it over with a jumpstart, after an age it just started. he reckoned new glo plugs, and cheap supermarket fuel is to blame, not got the right additives in, waxing up. now, the question is, how do they know that fuel from one place is different to another, has there been any evidence or is it just myth? shirley most people go to supermarkets for fuel, and doesn't it all come from the same refineries? sorry for rambling.
Tesco fuel has more horse power..........gets coat..
Different additives depending on the brand etc. Try putting some injector / fuel line cleaner in every now and then and give it a blast once in while.
Very good. (-:
As I understand it, supermarket fuel used to be crap. These days there's little difference.
I Am Not An Expert.
Firstly lol at sh.
Next up, most fuel supplied does indeed come only from a handle full of sources the general rule of thumb, which does change by region is,
Supermarket fuel = fuel that Is shipped in from the open market, normally of slightly out of spec grade thAt has additives to bring it back in line, will only be for cetane and lubricity on diesel maybe cold flow improvers. Gasoline will have something to bring the octaves back up. However, you will have locally produced fuel that goes both to supermarkets and the majors, the only difference is the inclusion of performance additives in the major stuff, very rarely like that in Tesco. She'll is different with its VPower stuff that the base is diesel / gasoline is much better, plus additives.
If the fuel was bubbly it was lacking an anti foaming agent,a big problem with minis actually..
I understand that most additives are added to the tanker, not the at the fuel depot, so the old 'Ive seen the same tanker go to different garages so it must all be the same' doesn't mean it is the same.
I would never put supermarket fuel in my car & with performance fuels I would always use shell over anyone else. I know people that have had problems using Tesco 99 ron fuel, you should check out the price of real 100 ron race fuel to understand the difference.
Obviously the above is just my opinion.
Cheers.
All fuel in the UK has to meet a set standard, suppliers then add additives for people willing to pay even more.
Aftermarket fuel treatments are a false economy, look at how much you spend vs the recommended treat rate and its cheaper to go with a decent fuel in the first place.
Edit, it costs not a lot to make a good 100 / 102Ron fuel,the cost is in the testing and margins are significantly more.
2nd edit, yes all fuel does have to meet the same standard, but as you can drive a bus through them the difference can be big.... it's still mostly down to additives though.
We use 'Asda Reference' fuel for any non-critical testing in our development cars (and critical tests use non-pump reference fuel) and it doesn't make any appreciable difference. A mix of V-power and other high octane fuels is used to make sure it all goes nicely on higher octane but 90% of the time it's standard Tesco/Asda unleaded or Diesel.
used, as in about 5 or 6 years ago, to have a diesel with a computer that gave me fuel usage info. at the same time was doing regular long runs in a day, to london for an afternoon meeting then back to west cornwall generally, anyhow consuming latte and m&s scotch eggs only takes a little time so with many idle hours i became quite a spotter on fuel consumpion. the basic result, with regards to diesel... tesco worst by far, shell very best. there were quite a few mpg difference in it as well.
Speed do you work for a big oem, there are vast differences which I am happy to talk about?
What Drac said Its marketting as all fuel has to be a set standard
You can even buy your own additives i you think you have not got enough from the "brand".
Not getting your point here- if it is added to the tanker then it must be the same in the tanker
My mate used to make bog roll all exactly the same [ they had budget standard and premium but all made the same but with different colours and patterns. this was not how it was marketted by those they supplied it to.
Tis not all marketing, partly but not all. Same with lubricants as well..
As far as i am aware there are no tests done using a selection of cars driven for 100,00 miles on one fuel and matched to another to see if there is any actual real difference in performance of fuel or engine so i go for measurable but negligible.
You can run a diesel on veg oil so i would not be massively worried personally
I'd be surprised if there was any performance difference, it all comes from the same refineries, meets the same BS standard and the supermarkets sell so much, that any issues/differences would be well documented by now.
nothing as far as i can tell, we've run two diesel cars for the last 8 years and always been supermarket fuel.
And Magnatec oil meets a different BS standard...
speed12 - Member
can you give us some more details? what area do you work in? cheers
With the poor running and poor starting along with bubbles in the fuel lines, I'd be inclined to think that it's drawing air in somewhere. Has it had any work done on the fuel system recently like having a fuel filter changed?
The RAC guy's suggestion that it's down to dodgy supermarket fuel is a load of nonsense that mechanics come out with when they don't know what's wrong. I know that first hand as I've heard colleagues of mine use the same excuse in the past when they didn't know what was wrong with a motor.
Sui, I work for a consultancy rather than an OEM, but working with them.
Definitely interested to hear anything you know of (do you work in the industry?). I would agree there is a difference between some fuels from supermarkets and the big fuel vendors, but what I was (badly..) trying to say was that in general it won't make a massive difference to your average man on the street. As I said, we use Carcal (and others) reference fuel for any critical testing (emissions, knock control, fuel adaption calibration etc), but generally fuel from 'wherever is closest' is used for day to day testing on road/track and there is not enough of a difference to effect results so I'd be fairly certain that an average driver wouldn't notice.
So yes there is a difference. No it isn't/shouldn't be a problem. My thoughts anyway! But as said, genuinely interested to hear if you think differently!
notmyrealname - MemberThe RAC guy's suggestion that it's down to dodgy supermarket fuel is a load of nonsense that mechanics come out with when they don't know what's wrong.
Aye, they gave that line to a mate of mine, but he's put nothing but branded premium in the car from new as he's easily led.
Go and put veg oil in a new high pressure common rail diesel, it will last 5 mins before damage is done.
Asda don't make any special types of fuel and it will change significantly seasonally and likely between loads depending on which terminal they decide to take it from, etc etc.. plus no additives which you would want for endurance running applications, mad not to really.
Speed you might inadvertently know me already.. how do you pm?
You can't PM.
i thought it was bs when he said it, after all, how do they know, do they test everyones fuel when they've broken down? no course not, this evening it started first time from cold, so don't think its glo plugs, he tested the current draw on them and it was 29 amps, he said it should be around 60.... gonna try it again in the morning, see what happensThe RAC guy's suggestion that it's down to dodgy supermarket fuel is a load of nonsense that mechanics come out with when they don't know what's wrong.
When did that stop then? Must have been back in the dark ages.. at the risk of spam attack. Sui on tour [ at ] hotmailcouk take out spaces.
Junkyard - MemberWhat Drac said Its marketting as all fuel has to be a set standard
most additives are added to the tanker, not the at the fuel depot, so the old'Ive seen the same tanker go to different garages so it must all be the same' doesn't mean it is the same.Not getting your point here- if it is added to the tanker then it must be the same in the tankerMy mate used to make bog roll all exactly the same [ they had budget standard and premium but all made the same but with different colours and patterns. this was not how it was marketted by those they supplied it to.
Tankers have separated tanks within the one tank you can see, does that make sense?
several years ago i was a fuel buyer for a large superamrket where every little helped..
the fuel at supermarkets comes from the same distribution centres as all other fuel retailers.. the only differences are slight detail specs on additives but frankly to fulfill quantities we 'd have to buy anything available so one day you may have a premium product instead of your standard fuel..
the biggest complaint we had was ' theres water in your diesel or your pumps are short changing me as my dial has hadly moved..
water levels are very acurately measured as in depth and percentage of fuel in the tank down to a 0.01 of a percent.
i can honestly say I never saw anything other than 0.00% on any measuring equipment in the three years i did the job..
as for your shortchanging me as my dial didnt move.. which do you think is the most accurate measure.. a £10k computerised unit that is serviced twice a year and subject to spot checks probably three times a year from weights and measures.. or that little needle that moves back and forth in your car..
Now I did once have a pump that told me I'd put 19 litres in my 16 litre tank. So it [i]can[/i] happen, stuff goes wrong.
Hmmm. well i'm no chemical engineer but we run a fleet of approx 150 ambulances and 100 odd response cars, some will be universally on supermaket fuel, some on big brand stuff. No one minds what gets put in other than a general encouragement to buy cheapest, and no mechanical issues have ever been attributed to crap fuel in the 5+ year(hard!)life of our vehicles. (We have plenty of other mechanical issues mind you, new clutch in your octavia at 23k miles? ouch)
I see nobody has mentioned morrisons diesel, any reason?
Not convinced about the former, the latter I've heard but not seen.
Pretty much everything exiting a refinery is to some specification or another. Generally you work out the cheapest way to meet that spec and configure your refinery to that. The margin's are pretty tight in refining so you're not going to try and make something 'better', it'll all be the cheapest. V-power is the exception, that's only made at Stanlow and is different.
V8- we've had clutches go at less than 5k on 12 plate wagons... Peugeots though!
Edit- and oil leaks, fuel leaks, and doors falling off.
Spoon, only meant as a rule of thumb, certainly not always.
Never started.
I'm sure back in the early days you could,I.e pre change over, either that or I'm thinking of the old choccyfoot site.
With no data or evidence to speak of, Sainsburys fuel (diesel) often seems to make my car sluggish.
Its all in the additives. The fuel from the depot is the same product for each grade. The amount of additive is miniscule but can make a hell of a difference.
In the UK we actually have relatively few kinds of fuel available at the pump and a non volatile market.
As to the poster with a fleet of ambos, youve also got a team of mechanics working almost round the clock and your engine rarely get turned off! And lets not get started on the electrics of the new fiats at NWAS or the batteries in the rrvs 😉
When i got my engine set up on the rolling road at Star performance they advised me to use Shell V-Power for the preceding 2 weeks before i turned up with the car for the session and i've only used V-Power since then (1 year ago), unfortunately the local garage that used to have Shell fuels and V-Power has recently changed over to Gulf and i'm not entirely convinced with regard to their premium fuel - it may be my perception but i'm sure the engine is pinking (abnormal combustion) when under hard acceleration, my nearest Shell garage that stocks V-Power is now 35 miles away..... 🙁 . As my engine is not standard and quite highly tuned along with being 25 yrs old and was specifically set up on the rolling road to run Shell V-Power it's gonna be an expensive trip just for fuel at 25mpg.
I use Tesco because I get Clubcard points. 8)
Used diesel from all major suppliers too and seen little if any difference in performance or economy.
Although its slightly off the dizzy topic.. Petrol spec of 95/98/99 RON can be attributed to the requirements of the car.. for example my 2.0 FSI (VW engine) Octavia has a noticeable difference with 98RON with MPG and perceived power due to the variable timing.. it also sorted all the ECU logs about it failing to over retard enough to compensate for poor fuel quality.. also it does long term engine damage due to carbon buildup etc etc
I'm too stingy to go to shell for v-power etc however, Tesco 99 normally.. I worked out the costs and I get around 6MPG better, which works around 2p a mile better off (at motorway cruising anyway)
still wish i had a diesel though 🙁
High pressure system on modern diesel injection, so only way air could get thru is from within the volume of fuel itself. Any bad seal etc. in the pipework would have fuel pi55ing out under pressure.
depends if the leak is before or after it becomes high pressure......
we have a transit that when ever its forced to run on tesco diesel (ie no other fuel stations in town and yer low) it will hunt and die and hunt and die and sometimes stall ....
yet on asda/shell/anyone else its absolutely bob on.
you can set your watch by it when you fill it at tesco it will give the symptoms - every time. coincidence maybe but too much for my liking. Ill actively avoid tesco fuel if i can in any of my cars.
In terms of things clogging up is that not more likely to be a function of what kind of driving than the fuel. Is doing loads of short journeys where the engine never gets hot with premium fuel comparable with someone who does hundreds of miles a week, all long journeys filling up at Tesco?
To be honest I've stopped using supermarket stuff I had loads of issues with it in my van now in my new (to me) car I always find it starts better using stuff from a local garage don't know why just does?
So always use that from now on
Short journeys can be a nightmare for some diesels as you don't get enough run time for DPF regeneration to happen, then it's a costly repair/replace when it goes.
also, common rail disels do re-circulate fuel and this can have a nasty effect on fuel that's in tank. As you will appreciate most fuel now will contain a portion of biodisel, this may be from virgin sources such as rape, soy, and some palm during summer months, but it will also containe UCOME (used cooking oil). Bio diesel is a bitch when it's heated as it starts to oxidise, once it oxidises it will form particulates in the fuel, these will block filters, they will clog injetors and all manner of aother nasty things happen (fuel pumps too. "Decent" fuel, i.e. those with an additive will also have anti-oxidants present, designed to slow this process down, it will always be uch more common in vehicles that sit idle for weeks/months on end. As well as an anti-oxidant it will also have a metal decativator in it, some metals within the fuel lines once oxidation has set in, will act as a catalyst, speeding up the oxidation process - and then the perpetual cycle commences.
edit - not just meatal in the fuel system, but also from the delivery mechanism (terminals, tankers, pumps etc), these will leech.
Might be something in this? My dad only ever drives 5 miles to the supermarket and back so fills up on supermarket fuel.
If i'm doing long journeys on the motorway, i might only ever be able to find Shell/BP etc. so fill up there.
Probably the journey distance has made the car feel better, but it gets blamed on the fuel?
I've yet to see any evidence supermarket fuel is worse, and certainly no evidence it acutally damages cars.
Fifth gear have done a few tests on the subject
They did a fuel test, testing supermarket against "Posh" fuels using a Golf GTI Edition 35, The Rolling Road they used was the very respected tuner R-Tech.
The fuels where fed directly into the HPFP Lines so no mixing of fuels happend, 4 runs where done for each fuel
Shell VPower (98ron) - 240.9bhp - £1.45/litre
Esso Supreme (97ron) - 240.5bhp - £1.44/litre
BP Ultimate (97ron) - 236.7bhp - £1.47/litre
BP (95ron) - 236.1bhp - £1.39/litre
Asda (95ron) - 235.8bhp - £1.36/litre
Looks like you get more power with the higher octane (no surprise then)
[url= http://singletrackworld.com/forum/topic/the-truth-about-supermarket-petrol ]Also discussed here[/url]
I reckon there's a lot of bollocks being talked in this thread personally. Doubt anyone could tell a difference in a blind test. 🙂
Looks like you get very slightly more power with the higher octane (no surprise then)
FTFY
There is, but I can only speak from personal experience. My old Volvo V70 T5 would return about 25mpg if I was careful from Shell's normal unleaded; if I used supermarket fuel, there was no appreciable drop in performance, but the fuel consumption would sometimes struggle to reach 20mpg. If I then went back to Shell/other forecourt branded fuel, hey presto! consumption figures back to normal. I haven't tried it with my new D5 but then I don't intend to.
Similarly, my old man's Skoda Octavia positively refuses to run on supermarket fuel. It struggles under load and returns typically 20-30% worse fuel economy compared to forecourt fuel.
The Transit introduces a slight misfire at really low fuel levels to remind you fill up. Range when the light is on is further than you think!
I simply don't believe there's any difference between supermarket fuel and filling station fuel. Assuming you're talking about the same octane etc, a buyer places an order with a supplier at the best possible price and organises a tanker to go to the refinery to pick up the fuel and deliver to the pumps. I'm pretty sure refineries don't make a cheaper blend of fuel for supermarkets, it would be a nightmare for them to manufacture and hold the stocks.
so reading back we've got people in the trade with first hand experience saying there's no difference whatsoever between branded fuels and supermarket fuel, indeed it all comes from the same source apart from shell v power, higher octane fuels give better performance figures as advertised, and a few people saying they think branded fuel makes their vehicle run better. there's been evidence cited that in tests all fuels are more or less the same. i think thats put this one to bed for me.
as for the van, its running fine now, it started 1st time this morning...
purely anectodtally but my vans sluggish drives like a tank when the mrs is driving but is okay when i m behind the wheel..
statistically mrs tts also has 0.3 accidents a year over the last twelve years where as i have 0.0 ..
its also a fact that i ll be dead if she reads this.
perhaps one piston refuses to work on supermarket fuel as its better than that ?
The power of the placebo is strong in this thread
If you want to use forecourt fuel do so but lease dont claim its cheaper to buy more expensive fuel
spchantler - Member
no we also have some industry experts 8) who says there are differnces, but it's complicated.
and by complicated you mean marginal 😉
perhaps one piston refuses to work on supermarket fuel as its better than that ?The power of the placebo is strong in this thread
What can't speak can't lie.
Fill it with supermarket diseasel - it coughs and splutters, won't pull and returns 45 - 50mpg
Fill it with ordinary Shell diesel - it runs fine and returns up to 60mpg.
10 gallons of supermarket fuel costs £63.64p and gives him 500 miles tops = 12.73p per mile.
10 gallons of Shell costs £64.96p and will give him about 600 miles = 10.83p per mile.
So yes, you're quite right - it does make more sense for him to buy supermarket fuel and I'm just telling fibs. 🙄
are these actual measurements? if not, its pointless working out your mileage rate, which is only 2p difference, lots of room for figure massaging in your calculations500 miles
Cant comment on mpg but filling up generally costs about the same from Asda or Shell but there are significant differences in miles before empty with the onboard computer. Generally look at a difference of 80 - 100 miles more using Shell than Asda diesel and generally across the board with other supermarket fuels. Fill up with 65 litres every 6 days from Shell every 5 days with Asda.
can i see your peer reviewed data etc ?
Anecdote, no matter how passionately delivered is not evidence.
Too many factors etc
Its not outlandish to suggest that the driver gives it more revs as they are under the belief they have 20-30 % less power and therefore got fewer miles
As i said there is no independent reviews that i am aware of that cover this issue
According to the Petrol Retailers Association, there is no difference between the standard petrol you buy from supermarkets or franchised petrol stations. In most cases the petrol and diesel is even produced at the same refinery and delivered in the same trucks.The exception to this is specialist fuels, such as Shell’s Optimax and BP’s Ultimate. In their case, the fuel is enhanced with additives, which produce that brand’s particular properties.
The standard fuels we tested were all up to the job, wheter from a major fuel brand or a supermarket.
'There's no conclusive evidence to show that super fuels are better for your car in the long run – so in a time of high oil prices, why would you choose to pay more?'
Believe what you want on this issue but your original post refers to standard products which are the same product from the same refinery just bought from a different place so identical , Even if it is a "super fuel" the difference is negligible
flounce alert
[url= http://singletrackworld.com/forum/topic/cartrackworld-diesel-donkey-glow-plugs ]here[/url]Shouldn't be glow plugs at 60k. Try chucking a tub of injector cleaner through it, change the fuel filter, and at risk of upsetting certain other forum members (cue full-on STW cock-fight) use forecourt fuel instead of supermarket...Oh and then go and cane the tits off it to clear the DPF out.
Seems like there's only one person getting upset.....
I power my hi-fi from a stand alone generator to avoid introducing mains noise, but I can clearly hear that the sound is less authentic when running on Tesco diesel.
Kcr - bravo! You have summed up the whole of stw in a single post! 🙂
As I mentioned previously.. VW 2.0 FSI engines can use the 98ron and has the capability in the ECU to adjust timings based on the higher octane number, meaning the fuel can be compressed more before detonating, it also allows the engine to run stratified for longer.
that said. the FSI had tons of problems with people sticking cheap fuel in them and having all sorts of issues.. and thats why VW stopped the FSI engine (turbo is continued)
Not all engines benefit from the higher octane.. but the ones that do will result in better performance and mileage.
My Focus 2.0l is largely responsible for climate change. My wife gets about 27mpg on Tesco petrol (95) and 30mpg on Jet petrol.
Do you remember when cars (mainly French) were conking out and supermarket fuel was to blame? At the time it was reported that supermarkets were buying fuel that was refined in Russia. The supermarkets denied it and said their fuel came from same UK refineries that the other garages used. I don't know where they get their fuel from, but like others, I do see a difference in fuel consumption. We only use Tesco if we've got a 5p off voucher.
snaps - MemberShell VPower (98ron) - 240.9bhp - £1.45/litre
Asda (95ron) - 235.8bhp - £1.36/litreLooks like you get more power with the higher octane (no surprise then)
But also that a price increase of about 7% gave a power increase of about 2%. Bargin!
If you are referring to the conking out issue from a few years back, that was down to supermarkets, mainly in the south supplied by greenergy who had bought a shed load of cheap out of spec gasoline, along with some cheap toluene to bring it back into spec. The toluene/styrene had been used as a solvent for washing and was reclaimed, it then polymerised causing polystyrene particles in the fuel.
I sometimes end up doing a lot of miles, and my car runs absolutely fine on supermarket diesel. If I fill up with nice diesel it runs every so slightly smoother. If I use cetane-improved shell V power or BP ultimate etc then it is clearly smoother, and starts better, but any increase in economy is less than the normal variation in economy due to weather, traffic etc. So no more than 1-2mpg.
The price difference between Ultimate and normal seems to still be 6-7p/l, as it has been for years. This was a much bigger percentage 10 years ago, and requires less MPG increase to make it cost effective. However I'm now driving a 60mpg car so I need more MPGs as well 🙂
I have just started using bp fuel and noticed a big improvement in performance and fuel economy compared to Morrisons fuel,after a recent service, and just out of interest, I cut through the fuel filter and it was full of black rubber like particles inside.. 😯
I obviously bought from the wrong place at the start of last winter (but couldn't remember where I'd last filled up a couple of months earlier). The diesel wouldn't start on a cold morning at altitude and there was no smell of diesl or white cloud: waxed diesel. Fortunately I'd parked it where it was all downhill and it came back to life once down in the valley.
globalti - MemberI simply don't believe there's any difference between supermarket fuel and filling station fuel. Assuming you're talking about the same octane etc, a buyer places an order with a supplier at the best possible price and organises a tanker to go to the refinery to pick up the fuel and deliver to the pumps. I'm pretty sure refineries don't make a cheaper blend of fuel for supermarkets, it would be a nightmare for them to manufacture and hold the stocks.
Did you read the stuff I bothered to write? I'm not bothered if you did or didn't, but have you really read this thread?
Cheers.
trail_rat - Memberdepends if the leak is before or after it becomes high pressure......
My van (2002 Trafic DCI) has a similar aversion to Tesco Diesel, and it caused me a load of Grief with blocked filters and ultimately a replacement Lift pump, HP fuel pump and a full flush of the tank and lines.
Thankfully I avoided replacement of all 4 injectors but the hassle was considerable.
That was one particular Supermarket, but I still have running problems
every time I am caught and have to refuel at Tesco.
All the other supermarket fuels seem fine ? (I fill up at Sainsburys more often than not as its on my way out from home)
V-Power was control fuel when I was at Cosworth Technology, as it was the most consistant. My Ducati ran much better on it and got better mpg too.
Edit: comment deleted.
