So theres a sensor that goes in the crank and under calibration in the menu it seems to imply there a lean sensor/gyro.
So it’ll know when you’re pedalling, going uphill, or downhill, or banked over in a corner and will adjust the front and rear damping to suit.
Very much like the electronic suspension motorbikes have had for a few years.
I’mnot sure I’d want it changing my suspension automatically, what about a a quick pump/natural roller, where you are briefly pointing uphill, and what about jump takeoffs?
Combining it with the gears and seatpost however…
you could have a descend setting when the seat was down, climb when its up.
Or link it to your gears if you only want stiff setup when climbing in the easy gears (no good for stiffening it up for sprints). All controlled via the same 3 buttons (gear up, gear down, dropper), and user customisable. That would be awesome.
