Viewing 8 posts - 1 through 8 (of 8 total)
  • Sliding vertical bike rack
  • dropoff
    Hi, has anyone sourced the parts and constructed their own system for bike storage instead of buying a complete rack ?
    alan1977
    following
    thought about buying the stashed products kit before now
    dropoff
    Yes Ive seen those but the price seems to rocket when you need a 6 bike version. Buller seem ok but are all out of stock.
    stumpy01
    Good info here.
    Garage bike storage
    I have a list of bits I should buy from rollincenter to replicate the system that Ogg created.
    Just not got round to planning it, ordering the bits & getting it done.
    tthew
    I build a telescopic rack for the back of my van, photo below doesn’t really show the detail, but the track is made from a folded metal U shape channel called Unistrut and there are cartridge bearings that roll inside it. Would easily mount to a wall or other structure, the only thing you’d need to concoct would be some kind of hook/bracket to attach the bearings to.
    DSC_0080
    dropoff
    Cheers that Rolling center is a good resource.
    jwh
    Yes – I built a 10 bike hanging system in my garage.
    Image: https://1drv.ms/i/s!ApWxLFzQYaHZgbZdCj83pXTA-JIL7g?e=hRBcku
    I used these items from here: https://www.rollingcenter.co.uk/products/Rolling-Center-80Z-galvanised-monorail-track
    Rolling Center G80Z Track Joint Bracket G80Z
    Rolling Center 80G non-galvanised monorail track 80G
    Rolling Center 2 RC 2 Wheeled Carriage with Bracket 2RC
    I made some of the hanging hooks from 8mm threaded bar and wrapped inner tube around them
    Works really well – you can’t twist the bikes round, but i have no need for that
    peanutcracknell
    I’ve done a similarthing to JWH. 10 bikes, 3 or 4 if which get used quite regularly and generally have enough space around them to be pulled out quickly, and the rest are pushed closer together most of the time (top n tailed to be even more space efficient) but when we need one of them it’s juat a few seconds sliding the others along to make space where it’s needed to get a different one out. Cost a touch over 100 quid I think, but I bought hooks rather than making them.
