Hey all,
I’ve got enough bits to build another bike but I want to do something different. I’m thinking of a singlespeed build but I need the collective wisdom of the STW crowd to answer the following questions (link to products would be good)…
1. I’ve only got campag compatible wheels, can these be converted to running siglespeed?
2. I don’t want to leave the full cassette on so that it all looks clean, are there any spacer kits and can I use and would a standard campag lock ring work?
3. I’ll be using a compact crank set 36/48 (I think), what’s the best ring to use and what’s the best rear cog to use it with (I use 12 -25 cassettes).
If all goes well I think this will look class.
Cheers.
