Evening all
After tearing my hair out all day bleeding my brakes repeatedly I think I’ve sussed the spongy back brake issue I know people have (after googling A LOT today).
If your back brake is soft but you are sure you’ve got the best bleed you can, stop bleeding them again and again. Instead, remove the rear wheel and pump the brake lever. Leave the pads in though, so you’re pressing the pads together after a few pumps. Don’t overdo it, it’ll just take 2 or 3 pumps for the piston to push out enough for them to touch and that’s all we want, don’t try to crush them. Now, release the lever and the piston will release a little too. Not enough to get the disc in so jimmy them apart a fraction so you can get your wheel in. Now your brake feels awesome.
I’m going to guess that this is an issue with needing a certain amount of fluid in the caliper body to displace a lodged bubble which, with new pads isn’t always achievable. By removing the spacer or disc you’re allowing additional fluid into the caliper body which you then push out again but you’ve filled the void which you can’t seem to on fresh pads and fresh oil with the spacer or disc. Now that I’ve thought about the issue and typed that, I think I’ll burp the reservoir tomorrow.
Might just be me, but seems to work on my SLX. Takes 2 minutes and no mess. Don’t open any bleed ports as you already know you’ve got a good bleed. Unless maybe you need a little burp.
Hope it helps.
Rick
