Volume reducer is an expensive bit of plastic you can put in the rear shock “Changing volume spacers in the shock is an internal adjustment that allows you to change the amount of mid stroke and bottom out resistance” … easy to do, you can buy kits from Mojo and probably TFT. I’ve had to use one before on multi-pivot biks but not my single pivot bikes.
