I have a renault trafic 2006 6 speed with 127000 miles on the clock. I now cant select 1st gear when the van is moving, even when the clutch is depressed. It will go into 1st when the van is stationary. All other gears seem fine. I know these gearboxes are trouble and it is likely that it is on its way out.
However, the van is insulated, carpeted, has a leisure battery, bed, flooring and apart from the gearbox is in good nick.
I am in two minds as to what to do. A recon gearbox will set me back around £700 plus fitting, so lets say £1500 all in. I would then hopefully then have a fixed van. However, with the age of the van, am i pouring £1500 down the drain if other issues arise ie engine fails.
Should i cut my losses and get another van. The issue with this is that all of the ‘camper’ mods wont be in it, so it will all need doing again.
