Oh aye, I was wondering about this- is it possible to get brake pipe end cap things that you can thread on when you remove a caliper? That’d be ace. I had a google last night but couldn’t find anything. Obviously you can clamp a rubber hose but that’s inelegant
molgrips
Subscriber
I bought one of those bleeding devices that fits onto a tyre and pushes fluid from the reservoir. Only I didn’t do the cap up properly and poured about 600ml of brake fluid through the engine compartment and onto the drive
Aye, they’ll do that. Partly because they’re a bit crap but also because 30psi in a tyre is way way more than is a good idea for this. If you want to use them then the best way is to buy a filler cap for your car off ebay and adapt the fitting for it, and then use a mostly flat tyre, IIRC 5psi worked well for me but that could be bobbins.
But sucking through with a big syringe is pretty much as effective unless you’re doing a whole system
