Quick invisiframe q...
[Closed] Quick invisiframe question.
8 Users
Carbon frame with the dull / Matt finish. If I have it invisiframed will it give it a shiny look or will it retain its flat look?
Posted : 31/07/2017 4:54 pm
Order the Matte kit
Posted : 31/07/2017 4:56 pm
Ask them for the definitive answer
Posted : 31/07/2017 4:57 pm
You can get gloss or matt invisiframe kits. Had a matt one put on a Matt carbon frame, made it a tiny bit shinier but nothing major
Posted : 31/07/2017 4:58 pm
Cheers fellas that's great.
Posted : 31/07/2017 5:01 pm
what do you reckon to fitting your own kit? Is it as easy as it looks or is worth paying your lbs to do it for you?
Posted : 31/07/2017 7:13 pm
It depends on how closely the level of matt-ness on your frame matches that of the tape. I know this is stating the obvious but there's quite a degree of variation in matt finishes.
If it's any use as a guide then the matt vinyl is close to but slightly shinier than the finish on a black Rockshox fork. It will probably be ok but less likely to be as 'invisible' as the gloss vinyl on gloss paint.
Re: fitting. If the frame is new or very clean and you are patient and good with your hands then give it a go.
Posted : 31/07/2017 7:16 pm
Cheers Joe, think I will give it a go. It's a brand new bike so want to get it done asap really.
Posted : 31/07/2017 7:40 pm
It's not too bad to fit; I've done three frames now. Justv are your time and follow the instructions and you'll be reet.
Posted : 31/07/2017 7:41 pm
Just got to make sure they have a kit in for my frame then going to order one. Thanks again chaps.
Posted : 31/07/2017 7:45 pm
Ive done 4.
Top tips - clean the bike with isopropyl alchohol, use a teaspoon of baby shampoo in 500ml of water. Use a spray bottle to apply the water.
Takes a few hours, even for my 4th one.
Use warm water and wet your fingers, the frame and the invisi kit.
Some bits take a while to stick, squeegee out the water, then go back 20 mins later and try sticking down the edges that were an issue.
Posted : 31/07/2017 9:03 pm
It's not hard but does take time. The amount of soap seems to vary with temp. But it's all in the instructions
But
Clean work space , clear bench , clean hands and clean degreased bike
Posted : 31/07/2017 9:08 pm
