Quick fit roof bars
[Closed] Quick fit roof bars
12 Users
Offline  fanatic278
Share this post
Car has broken down again. Time for a new one I think.
What small cars (Fiesta sized) have quick fit roof bar systems? I've never found a system that isn't a fiddle to get on. I just want one that clips in - no screwing things, or bolts, or knobs. Just click and go.
Does a car/rack combination fit my requirements?
Posted : 23/01/2018 1:36 pm
Offline  fossy
Share this post
It's more of a faff lifting one on. Our 4 bike rack and aero bars weighs a tonne and is a 2 person job.
Mine just needs the doors opening and the bracket locates into a slot but you still have to tighten the feet down.
Posted : 23/01/2018 1:52 pm
Offline  fanatic278
Share this post
I'd like to avoid the foot tightening palaver - if possible.
Posted : 23/01/2018 2:09 pm
Offline  legend
Share this post
Sounds more like you want a Sea Sucker (or the Sea Sucker imitation brand that I forget the name of)?
Posted : 23/01/2018 2:22 pm
Offline  fanatic278
Share this post
Thanks for the tip. Just watched on YouTube and it looked like lots of pumping though. And limits me to carrying just one bike.
Posted : 23/01/2018 2:38 pm
Offline  legend
Share this post
How so? There's a 2 bike version available.
Considered a tow bar rack if every roof option has something going against it?
Posted : 23/01/2018 2:44 pm
Offline  matt_outandabout
Share this post
Our Seat Ibiza ST has the ones that are quick to put on - a couple of 'dints' in a rail.
The fastest ones I have ever had were just 'old' rail - with clamp around. Like these. I am not sure how many small cars have them any more.
Posted : 23/01/2018 2:46 pm
Offline  fanatic278
Share this post
Roof rails would be great, but unlikely to be fitted on a second hand small hatchback (presumably your Seat is an estate version?). I do know a VW Polo Dune has roof rails as standard, but not found one in my searches.
Posted : 23/01/2018 2:54 pm
Offline  jambourgie
Share this post
My Thule bars were easy to put on, about twenty minutes with an Allen key. If that.
Are you planning on removing them after each use or something? Surely they’re fit and forget?
Posted : 23/01/2018 3:20 pm
Share this post
It is not exactly huge car, and most folk do not realise it is the estate. It is a Polo with a few extra cm in the rear.
Posted : 23/01/2018 3:33 pm
Offline  simon_g
Share this post
Golf estate still does.
Haven't ever seen a system that quickly fits and removes from the car. Better IMO to get nicer aero bars with the T-tracks then they don't make noise and barely affect MPG. Then it's quick and easy to slide in a bike carrier when you need it. Take them off once a year to clean under/inside and give them a lube and they'll be fine.
Posted : 23/01/2018 3:40 pm
Share this post
I have found the answer. You won't like it, but it is here.
The 2006 Hyundai Getz or Getz Cross
Posted : 23/01/2018 4:02 pm
Offline  fanatic278
Share this post
You're quite right 😀
I'll keep an eye out for the Seat estate. Actually I'm all for having a small estate - I just don't expect to see one in my budget (£6k).
I'm intrigued about these aerobar things. If it doesn't impact on MPG then my twice daily 15 mile commute wouldn't necessitate taking them off. That would work.
Posted : 23/01/2018 5:50 pm
Offline  jca
Share this post
Take a look at whispbars for the most aero option. They attach via feet sold separately which cost £25 a set, so changing cars doesn't mean having to replace the whole thing
Posted : 23/01/2018 5:56 pm
Offline  unfitgeezer
Share this post
Small estate
http://www.autotrader.co.uk/classified/advert/201712182135387?atmobcid=soc3
Posted : 23/01/2018 6:40 pm
Offline  DickBarton
Share this post
As all the suitable suggestions have been knocked back due to being too much effort, why not ride your bike to where you need to go? Or hire a servant and get them to do all the 5-minute stuff? Or buy a solution, set it up once and leave it on...then just lift, lock and go?
Posted : 23/01/2018 6:47 pm
Offline  DickBarton
Share this post
Sea Sucker does a 3 bike carrier as well...needs a clean roof to stick to.
Posted : 23/01/2018 6:51 pm
Share this post
SEAT Ibiza ST's, under budget.
In fact, I might be selling our 2012, 1.4 16v, 60k, two women owners from new with full service history and cam belt done...
https://www.autotrader.co.uk/car-search?postcode=fk159hx&radius=40&make=SEAT&model=IBIZA&onesearchad=Used&onesearchad=Nearly%20New&onesearchad=New&year-from=2008&body-type=Estate&price-to=6000&advertising-location=at_cars&page=1
Posted : 23/01/2018 8:03 pm
Offline  craigbroadbent
Share this post
Seasucker is relying on a vacuum, which is pretty precarious. Same technology as old satnav and we know how long they stay stuck.  There is a plan to outlaw them, but not yet formalised by International Standards Organisation.
Remember you are responsible for the load.  Please add a cable back to a non-vacuum fix if you are going to use.
Posted : 25/01/2018 9:50 am
Offline  fanatic278
Share this post
OK - so there are no Seat Ibiza estates near me (Aberdeenshire). But I did find this Mini Countryman:
Mini Coutryman
http://www.autosalescars.co.uk/cars/mini/countryman/one/158026/0
It has little roof rails. Anyone got first hand experience?
Posted : 26/01/2018 7:51 pm
Offline  ratherbeintobago
Share this post
To fail to answer your question, wife’s last car was ‘60 plate Astra J which had roof hardpoints and getting the bars on and off was a doddle.
Posted : 26/01/2018 8:52 pm
Offline  aracer
Share this post
I'm not sure it meets the OP's need, as it requires proper roof rails, but the roof rack I had for my old car was proper quick fit and release with a lever operated clamp on each foot. Unfortunately it also only fitted narrow style roof bars and my current car has much fatter ones. In case anybody is interested it was Vauxhall branded and bought at a Vauxhall dealership - appears to be made by Thule (uses their bar system), but not sold as a Thule branded thing - though it was also bought quite a long time ago so may be discontinued (but if anybody has a car with narrow roof rails I still have it...)
Posted : 26/01/2018 9:43 pm
Secret Diary Of Benjamin Haworth Age 47 3/4
Last Minute Tuscany
Digital Detox
singletrack issue 159 cover image
Issue 159
