Community
Probably stupid cra...
[Closed] Probably stupid crank and bb compatibility question.
Help a chap out, I am super confused about compatibility.
I have this crank SLX M7100 12 speed. I aim to use it as a single ring 1 x 11 set up, I bought the slx 12 speed chain ring too.
https://www.wiggle.co.uk/shimano-slx-m7100-12-speed-crankset
a) Will it work with 11 speed chain, cassette, shifter etc..
ii) Literature recommends BB MT800 bottom bracket, which is the XT one. However I have in my spares drawer 2 x BB52 , will these work? I'm not a cheapskate but I don't have much use for these BB's otherwise.
TIA
Posted : 10/05/2021 10:24 am
they are all hollowtech II so no problem as they are all BSA threaded 68/73mm
the BB52 Deore has regular size cups (silver in colour) (so use a regular shimano TL-FC32 spanner or park BBT-9)
the black cupped MT800 BB will just have the smaller diametre cups where you need a plastic adaptor TL-FC25 to fit on the regular shimano BB tool (16 notches 44m diametre) or get a TL-FC41 (which has same notches as on the 12s chainring direct mount lock)
wow £30 each, i paid £8-12 on 3 i have in my spares bin :0)
i've done similiar research and fitment this weekend; swapping an XT and BB52 from one to another bike and putting an MT800 /XTR on.. works fine.
note spacer goes on driveside.
in terms of the chainring i cant comment, probably be alright as its got a narrow/wide profile would be my thought
Posted : 10/05/2021 10:39 am
Looking for the like button, cheers, good input.
Posted : 10/05/2021 10:52 am
no problem, it seems to be a minefield. was researching at the weekend as could do with a proper spanner, as my current one is made of cheese
only difference is cup size on the MT800 for XT/SLX & BB92 for XTR is smaller, circa 40mm.
hence the need for the plastic adaptor, or a new tool (that is worth the money as it matches on the 12s chainring lockring)
the BB80 Saint // BB52 Deore are regular sized cups = 44mm 16 notch cups
Posted : 10/05/2021 11:16 am
FYI My crank came with this tool in the box.
Posted : 10/05/2021 11:21 am
ah ok, i read a rant on here last week that they'd bought the XT crankset (OEM) and no tool..
Posted : 10/05/2021 3:50 pm
BB52 ?, cheapskate 🤣, personally I use the Lezyne bb tool that fit a socket wrench, much better than the spanner types, I prefer using the plastic adapter for mt800 so it doesn't mark up the black cups.
Posted : 10/05/2021 4:58 pm
Whatyadoinsucka, if you're referring to me it wasn't OEM, I wouldn't use tl-fc41 on the MT800 bb, the splines are a tad shallow imo so could chew up a stubborn removal. The tools that go on 1/2 or 3/8 socket wrench like the lezyne mentioned above are the best for bottom brackets
Posted : 10/05/2021 5:27 pm
I am running a 12-speed SLX crank set on my hard tail with 11-speed cassette, chain, rd and shifter without any problems.
Crack on, I say.
Posted : 10/05/2021 6:19 pm
I am on fitting now, I assume the crank handles the boost part.
I have a 73mm bottom bracket shell, so just one 2.5mm spacer on the drive side?
Posted : 23/05/2021 2:03 pm
Yes
Posted : 23/05/2021 2:19 pm
Depending on the frame it's going on and chainring size, be careful to watch the clearance on the chain stay when installing the crank.
I've had a few that were too tight with a 34T ring and it is so easy to take a chunk out of the frame very quickly if you don't spot it.
Posted : 23/05/2021 3:12 pm
Thanks everyone.
No fear of frame contact, I have 30T as I am a bit of a biffer..
Posted : 23/05/2021 5:02 pm
