Les Mills' Body Pum...
[Closed] Les Mills' Body Pump class - obvs Will I die?
[#10773546]
Thought I'd give it a go. Anyone done it?
Ta
Posted : 19/08/2019 4:10 pm
I go a couple of times a week as well as doing other classes, think it has helped with the biking and upper body strength. You will be fine, I think.
Posted : 19/08/2019 5:18 pm
Depends.
How many bodies  do you need to pump?
Posted : 19/08/2019 5:28 pm
I've done it for years. An hour class will follow a set routine with a few different moves within each routine and usually a change of speed. A typical one hour class will be as follows: warm-up; squats; chest; back; triceps; biceps; lunges; shoulders; abs; warm-down / stretches - a 45 minute class will probably combine some of the sets e.g. triceps and biceps. They change the releases every 3 months or so which can make a particular track much harder / easier than on the previous release. Don't do what many guys do and try and use the same size weights as you would in the gym - I've seen a few embarrassed guys having to drop the weight mid-track. Also try and focus on getting the technique right - I've seen quite a few people in the classes I do get the technique wrong e.g. deadlift or clean & press which sometimes the instructor doesn't pick up. Overall its an enjoyable and time efficient way to improve and maintain your fitness.
Posted : 19/08/2019 6:50 pm
Misread that as 'Les Mis Body Pump'. Which would have been a novelty.
Posted : 19/08/2019 6:53 pm
martinhutch
Subscriber
Misread that as ‘Les Mis Body Pump’. Which would have been a novelty.
Will you join in our crusade who would be strong and pump with me
Posted : 19/08/2019 7:26 pm
Well I did it and it was good. I have a feeling I'm going to ache tomorrow. Result!
Posted : 19/08/2019 9:49 pm
