Integrated tyre pre...
[Closed] Integrated tyre pressure adjustment system
14 Users
Offline  thols2
Share this post
Do people really see the need to adjust their tyre pressure multiple times per ride? I just can't see the benefit being worth the cost and hassle.
https://gravaa.com/
Posted : 23/01/2021 2:26 am
Offline  seadog101
Share this post
Once more an expensive solution looking for a problem to solve.
I can only see more hassle that its extra weight is worth.
Posted : 23/01/2021 2:57 am
Online  Poopscoop
Share this post
I agree, one more thing to go wrong. An evolutionary dead end I would think.
Still, I do like some of the odd ideas that come along in biking but most just stay odd and don't go anywhere.
Posted : 23/01/2021 5:43 am
Offline  thols2
Share this post
I think you could DIY by ziptying a can of sealant into the spokes and screwing the hose onto the valve.
Posted : 23/01/2021 6:05 am
Offline  nickjb
Share this post
I can see that being very useful, especially if you ride mixed terrain. You could say similar things about dropper posts but they are pretty ubiquitous now.
Posted : 23/01/2021 6:09 am
Online  Poopscoop
Share this post
Just read their brief. I take it back. There isn't one more thing to go wrong. Sounds like there are a LOT of things to go wrong...
Integrating a mini pump, clutch and electronics etc into hubs? On top of all the other things that can go wrong in a normal hub?
No thanks.
miniature high-pressure pump is stored, which is driven by the rotation of your wheels. Via an integrated clutch unit and electro-pneumatic control system the pump gets only active on demand.
Posted : 23/01/2021 6:11 am
Offline  n0b0dy0ftheg0at
Share this post
Could be useful for gravel riders, raise for tarmac, lower for offroad... Or you could just take a decent pump with a pressure gauge.
Posted : 23/01/2021 7:38 am
Offline  bruneep
Share this post
the advantages listed:
Save weight; never the need to carry a heavy saddlebag or pump during your rides anymore!
No weights given for their system I notice
Posted : 23/01/2021 7:45 am
Offline  jeffl
Share this post
I did wonder about a system to do this on bikes. My initial thoughts were a CO2 canister and something to control it. Reason being that I have quite a bit of road/cycle path work if I want to ride the MTB in the peak district. I generally get round it but overpumping the tyres then letting some air out when I get to the propper trails.
Posted : 23/01/2021 8:38 am
Offline  Tim
Share this post
Solution looking for a problem.
Posted : 23/01/2021 1:46 pm
Offline  K
Share this post
Come on, replace one of the spokes with a tube at least and finish the job properly.
Posted : 23/01/2021 1:53 pm
Offline  leffeboy
Share this post
nothing new under the sun here
Indiegogo: On-The-Fly Adjustable Tyre Pressure | Singletrack Magazine (singletrackworld.com)
But yes, it does seem a bit niche in the end
Posted : 23/01/2021 1:57 pm
Offline  danmac
Share this post
When did people stop just riding bikes and start inventing 'problems' that don't seem to exist
Posted : 24/01/2021 11:30 am
Offline  jameso
Share this post
Important product if you think hard tyres are important for riding on tarmac.
Posted : 24/01/2021 11:36 am
Offline  tjagain
Share this post
For the fatty I would find it useful as I have miles of tarmac to get to the trails. 15 psi to ride out, 8 psi on the trail, 15 to ride home.
what i actually do is blow up to 15 psi before I leave home, drop to 8 on the trails and ride home again on 8 psi.
Posted : 24/01/2021 12:03 pm
Offline  timbog160
Share this post
DUKWs had central tyre inflation in 1942, and its been used in many military and off-road applications since. So it’s nothing new as a concept but this is the first time I’ve seen it applied to a bike. I can’t see it being possible to make it light enough, or reliable enough, or cheap enough to be worthwhile. It won’t even do away with the need for a rucksack, since you can always just strap a cheap compact pump to your frame.
Posted : 24/01/2021 12:59 pm
Secret Diary Of Benjamin Haworth Age 47 3/4
Last Minute Tuscany
Digital Detox
singletrack issue 159 cover image
Issue 159
