I installed around 40 large softwood sleepers, I tried a couple of methods but by far the fastest was an electric chainsaw. Probably 100+ cuts.
I didn’t need to worry too much about the cuts so did them all freehand, and used a basic chain which I suspect is a ripping chain. As I was freehand, the chain would skate around slightly on the surface before digging in.
If you get a suitable chain, and make some sort of jig or guide for the chainsaw you could probably make a very good job of it.
Having watched a boatbuilding series on YouTube, I’m sure you’ll find there are various modifications to create a fixed chop saw style chainsaw, also I’ve seen a second handle bolted to the end of the bar so you can have someone both ends.
Hand cutting was incredibly slow, and my sharp circular saw just started smoking and burning, probably as the wood was damp.
