Brakes are c18 months old. Boiled the front last October in Basque Spain and lost the last run of the holiday. Bled in a car park for a few more days riding and noticed i’d pinched the seal when i’d bled after trimming hoses when fitting. Guessed that was why they needed bleeding.
Changed seals and bled again when i got home. Not much use over winter (was on hardtail) but two weeks big riding plus weekends in spring but last weekend the front was rubbing and then locked on.
I guessed sticky pistons so lubed them and they were retracting easily but the front brake locked on again this weekend. Let a bit of fluid out a the nipple and rode off the rear for the rest of the ride)
Not sure what the fault is – they shouldn’t need bleeding after only 6 months (and it was surrey hills riding so it’s not like they were being tested on long descents). Suggestions? I’ve not come across this problem with Hope’s before and ridden them since they first made discs
