Hi,
The cheap and nasty hub that comes as standard on the back of my GF Rig has died and so I’m looking to replace it with a quality unit. At first I thought a Hope singlespeed/trials unit would do the trick (which I’m sure it would) but then I got to thinking that if I got the Pro II I could slap some gears on the bike if I fancied doing some long distance rides on it (the Rig has the option to run gears).
The question is, will the alloy carrier on a Pro II be strong enough to run a single cog on? My other Hope hub with a titanium carrier has lots of (small) gouges on the carrier splines when the load is spread over a big area, so will running one cog totally kipper it?
Anyone out there been running a Hope Pro II with a single cog on it for sometime? Your comments would be appreaciated.
VC
