Community
HELP! shimano m765 ...
[Closed] HELP! shimano m765 rear brake/inbred question
 taka
hi there,
after being quoted £28 after i took the bike in to do the job im not paying that to get it done
what the problem is i have sold and on-one inbred 456 frame and a shimano xt m765 rear brake to 2 different people the brake has been threaded through the correct routings on the frame meaning it needsthe hose takeing off to unthread it out of the frame the slight downside is... i dont know how to do it? if you disconect the hose from the lever end see pic below
its the bottom left thing that causing the problem because i cant remove the 4th &5th thing in because its in the way how do i get it off?
caliper
brakes
[img][/img]
[img][/img]
[img][/img]
Posted : 19/08/2009 9:04 pm
Snip it off. The buyer will have to fit a new olive (that's what it's called) anyway.
Posted : 19/08/2009 9:10 pm
need to cut it off
get a new olive and insert from LBS
re attach
bleed
done
Unbolt the calliper and thread it around the frame. I'm sorry if I don't understand the question.
Posted : 19/08/2009 9:11 pm
 taka
cheers looks like a job for the cable cutters and a new olive then
cheers tom
Posted : 19/08/2009 9:26 pm
I doubt the banjo fittings will fit through the hose guides in the frame!
Cut the hose to get rid of olive / barb in there, thread hose through guides, slide rubber cover (5th from left) on hose, slide black locking nut (4th from left) on hose, slide olive (1st on left) on hose, put barb (2nd from left) in the end of the hose, then push hose into lever end, thread locking nut into lever whilst pushing hose into lever and tighten. Locking nut pushes olive into lever squishes it and compresses onto hose and locking barb in place. Slide rubber cover over locking nut.
Bleed brakes, test then ride.
Posted : 19/08/2009 9:36 pm
Obviously where you've sold the brake, and i cant read posts properly dont thread through the frame!
Posted : 19/08/2009 9:37 pm
Tom, don't worry, just undo the black nut under the rubber cover at the lever end. When it's loose and sliding down along the hose, pull the hose out of the lever, and then cut the hose about 15mm from the end, 5-6mm past the brass olive. You can then pull it through the frame. Bung all the bits in the parcel and I'll sort it out at this end. It is no hassle for me. Don't worry about the bleed.
Posted : 19/08/2009 9:45 pm
 taka
lol cheers off to other lbs to buy a new olive tomorrow
tom
Posted : 19/08/2009 9:46 pm
Don't worry about the olive! I have some.
Posted : 19/08/2009 10:06 pm
 taka
ok then you must have posted yours before mine
tom
ps it will be in the post tomorrow
Posted : 19/08/2009 10:10 pm
