For winter use, for the large-thighed large-arsed rider.
Humvee trousers look ok (I like the shorts and they *just* fit my thighs) but some saying they get very flappy in the wet.
Singletrack IIs look like there'll be too much fabric up front and might bunch up when riding, but would otherwise be ideal.
In proper winter I just go for tights, fashion isn't worth it for the sake of practicality and warmth
MT500s look good - stretch panels usually help me out, and since they'd be used in the cold the heavier weight would work.
In proper winter I just go for tights, fashion isn't worth it for practicality and warmth
Correct answer. If you must, wear your baggy shorts over the top, but Lycra is just plain better in the mud and rain.
Tights plus knee pads aint gonna work very well though
and thrice tights. Just plain practical
I've used Singletracks for winter and had little issue with them. Tights and waterproof shorts are almost always a better option though.
Stick pads over the tights I guess, I'd have thought pads under trousers was very unlikely to work unless they are like DH/MX pantaloons
I like my norrona trews, and my lycra tights too actually
I have tights which I wear sometimes, but I also fancy trousers. Don't ask why, I just do. I don't wear pads.
Personally, I find the secret to comfortable pads is to have something underneath them, so tights work just fine for me. In fact, even in summer I tend to wear 3/4 bibs under my shorts so that they extend under the pads. We're all different though.
Rubber_Buccaneer - MemberStick pads over the tights I guess, I'd have thought pads under trousers was very unlikely to work unless they are like DH/MX pantaloons
Pads over anything tends to be a recipe for them not staying in place. Wouldn't expect to get big pads under anything, just something fairly low-profile. DH trews aren't actually that baggy tbh, but just a bit too hot/heavy for pedalling in unless it's truely horrid.
MX trews are just wrong unless worn with MX boots..... on an MX bike
Consensus? On STW?
Roubaix bib shorts, pads and baggies will provide sufficient winter warmth for most situations if you're south of the border legend.
As for molgrips, if you just want them, well, good luck...
I've been riding in all weathers, winter and summer for over 20 years, so I've worn a lot of tights and shorts combos and been warm, cold, wet, dry, all of it. Bib tights aren't that confortable on the shoulders and back, and I don't find two lots of waistbands comfortable either.
Question is does anyone know of good pair of MTB trousers?
Next time someone asks for coffee recommendations I'll just tell them what tea I drink shall I? ๐
munrobiker - MemberRoubaix bib shorts, pads and baggies will provide sufficient winter warmth for most situations if you're south of the border legend.
* you, * teuchter ๐ North of the border thank you very much.
Staple for me is very close to that. Normal bibs/liners, pads, decent socks, decent baggies. Basically leaves around 2 inches of exposed skin above the sock and that's it. Once last year I rode in DH trews, and once (in biblical conditions) with the baggies replaced by waterproof trousers - that was an exceptional day though ๐ฏ Like your thinking with the Roubaix bibs....
Really? If they are tight then you should probably try and find a different brand that fits better, you should be able to pretty much forget you have the straps on.
Bib tights aren't that comfortable on the shoulders and back, and I don't find two lots of waistbands comfortable either.
May I, somewhat provocatively, suggest that you either buy some bibs that fit thereby fixing the first point, or don't wear baggy shorts on top thereby fixing the second?
Or just buy some trousers which don't work as well. Your call.
As said, thread is about trousers.
Ok so can someone please talk about why trousers aren't good?
Have we found a consensus on good riding trousers
The consensus is there are (and can never be) such a thing as good riding trousers.
Always excessively baggy, don't stretch as you move, rub you as they crease, make noises rubbing on bike, catch in the chainring, not as warm as a roubaix warmer/tight, don't breath well if waterproof and if not waterproof then weigh a ton when wet.
That said, everyone should own an emergency pair of waterproof trousers as in the most horrific conditions, its worth the drawbacks. For example I wore mine over leg warmers descending the Tourmalet in the snow - kept me dry and warm in conditions that could have been dangerous otherwise.
Flappy legs near chainrings
Wet flappy material getting cold and flapping against skin
Wet flappy material dragging over knees
Endura mt500 Trousers seem to be built to last, I had Gore ones which were great till they fell apart.
Ron...
Hill...
Bikesters.
I have some troy Lee dh trousers. They are fine but in depths of winter I still wear tights with shorts and pads.
I can fit the knee pads under the trousers. They are very robust, but not particularly warm. Good for keeping brambles off though ๐
They get wet, heavy and flap about. Then they start to restrict movement as they cling onto your legs. Then all that fabric starts to chafe. They're also not as warm.
Other than that, they work perfectly...
jimmy - Member
Ron...Hill...
Bikesters.
They are more like baggy tights aren't they. I have some ancient tracksters I used to climb in, they will outlast the cockroaches
I answered your question.
I find trousers good when it's cold and dry (or even when there's snow on the ground). Also handy if you're heading to the pub/cinema/restaurant and you don't want to be in obvious biking gear. The Singletracks can be cinched in at the ankle to avoid chainring clashes and have some reflective bits to assist in being seen by traffic. Decent pockets and vents too.
Which trousers did you all use?
I had some pretty good stretch soft-shell outdoor trousers from REI which were ideal - no flappiness, warm, good in the wet, but they lacked ankle straps (despite being relatively slim at the ankle they still caught occasionally) and they wore through after three winters or so.
So good trousers can exist.
[quote=scotroutes ]I've used Singletracks for winter and had little issue with them.
I'd go for the Ron Hills if normal cycling tights don't suit. Or fleece tights if its cold.
If you really want trousers looking in the climbing shops. Most are too loose but some are a close fit and you can always tuck tem in your socks.
endura used to make weather pants which are very good.
[url= http://www.endurasport.com/products/browse/?setFilter=1&FilterStr=|DEMOGRAPHIC_3|NAV_CAT_8| ]endura range[/url]
As I said above, I'm in the bib tights camp, but I do have a pair of Singletrack trousers, which I use on those rare days when it is dry. Tend to use them more for hiking in to be honest and wouldn't fancy riding in them any time the trails are wet (which is 90% of the time up here), but on a cold dry day they are perfect ๐
Whilst i was sceptical before buying I'd recommend the MT500 Endura waterproof trousers. I run hot but these are excellent to the point where I wore them on a wet 11 degree night ride with knee pads and lycra shorts underneath and was fine. Lack of pockets is only downside. That said only a couple of rides in so we shall see how they hold up over time. Endura sizing, as usual, is a complete abomination so definitely a try it on or order a few pairs. They come up a fair bit smaller than the chart suggests but fortunately lbs had the complete range of sizes.
Gotama, is that the Waterproof Overtrousers or the Spray Trousers? I like the look of the Spray Trousers (the shorts and 3/4 are good).
Bib tights (that fit) and endura hummvee (3/4).
I don't wear pads as I am [s]an XC mincer[/s] [s]fearless[/s] [s]stupid[/s] hard as nails. If it's going to be snow of any depth,I put on gaiters.
Slowoldman....the full on waterproof numbers. Ones in the linky below. I had a pair of the Spray shorts which I thought were pretty poor to be honest which was part of the reason I was sceptical about the full waterproof ones. A review on Pinkbike persuaded me to give them a try and glad I did. They breathe incredibly well and the completely waterproof aspect without any DWR treating style faff is what I was after.
http://www.endurasport.com/products/?ProductID=759&initcode=E8060BK
as some of you know, I like to call for liquid refreshment whilst out cycling.
and for all the money in the world, I would not be seen in a pub wearing anything tight and lycra.
so this winter I shall be wearing some nice waxed Fjallraven trouser for riding in.
warm, modest and enough style for a old bloke.
I use these sometimes https://www.snowandrock.com/p/the-north-face-men-s-horizon-convertible-pant-A1B13195.123.html?channel_code=300&s2m_product_id=67011_123&gclid=CLqrntbN_c8CFewy0wodIysM-g&gclsrc=aw.ds
Dry really quickly and are loose enough to ride in. Not as good as 3/4 bibs and baggies though.
Over the years it's been water proof shorts, waterproof trousers and full length tights. However, I've had to review that because this last year's are all padded up rides, so tights don't work. Waterproof full calf socks, sit just under the pad and then normal under shorts and water proof shorts seem to be the most comfortable.
Potentially horrific levels of chaffing though?
at the speed i cycle, very doubtful. ๐
Fair enough!
Anyone tried keela roadrunners?
On my recent trip round the Inner Cairngorm Loop I was clad in Endura Singletracks.
Yes the leg ends flapped about a bit but they had the benefit of effectively forming a seal with my boots to stop water flowing over and into them when crossing rivers. Very much appreciated when crossing at the Fords of Avon!
They can get quite hot though, opening the thigh vent zips helps a lot.
Main issue is that when the ends get wet they get heavy and they tend to slip down requiring a lot hiking them up all the time.
Was impressed with the Endurance MT599 3/4, I'd have thought the trousers would be worth a go.
But waterproof bibs are better than soaked baggies!
Showers Pass
I've ridden quite a bit in my mammut BASE jumps. They aren't bike specific but do the job for me.
Ooh, I wear basejumps for walking. Never thought of trying them on the bike.
So, no consensus
Anyone else using Fjallraven's?
Just went for a ride with the dog, wore a pair of Montane Terras. They worked better than expected, the poppers at the ankles really help
What sort of weight are the Montane's?
Given them much abuse yet for durability?
Terras come in a range of fabrics but the standard ones are pretty lightweight. Having said that, mine have survived several years of summer Munro bashing including Cuillin scrambling
In response the the OP, I'd say "no".
Terrible weather (especially at night): biblongs
Cold weather with pub stop: biblongs with baggies
Cold weather where pads are a good idea: pads on top of biblongs with baggies.
I can see for very long trips, gentle pace, or very cold weather, trousers would be good.
I generally go with bib shorts, Roubaix leg warmers, and shorts over the top (waterproof shorts if it's wet, normal if it's not) a combo which works well with knee pads.
If the weather is bad I have a pair of MT500 long trousers. There's no way of fitting pads underneath and they don't come high enough up my back. I feel like I'm flashing builders cleavage as they are constantly slipping down. I'll be trying braces on them this winter!
Have a look at the Madison Adict long trousers. I have the waterproof shorts which are great.
