They leak round the pistons. And the main sign is a HOWL
Are we sure about that ?. As a few months back i read a link to a forum post, that talked about the leak is coming from the oil transfer port, something to do with the O ring not sealing well enough.
It was being claimed that the o ring doesn’t sit high enough so when you close up the 2 caliper sides, the o ring doesn’t compress enough.
The rear on the Ebike has the prob, pretty much non functional and as im swopping them to Hope V calipers, I thought I’d dismantle the duff one to see if i can confirm as to where the leak is exactly.
I reckon when i split the caliper, if the metal that is normally sealed up is wet, then its possibly the port as the port is in the middle, but if its dry, then fluid is coming from elsewhere and that could be the pistons.
