Fox 32 Float Step C...
[Closed] Fox 32 Float Step Cast - DIY lower leg removal
3 Users
Offline  beamers
Share this post
Morning all
I'm after some advice on how to remove the lower legs on the above forks without shelling out for the specific Fox tool (£60.)
Has anyone got a handy work around? This is a bit more challenging with the Step Cast fork as the damper/spring assemblies are quite a long way up inside the lowers and not sticking out of the bottom as would be the case on a non Step Cast fork.
Any ideas? Ta in advance.
Posted : 03/12/2019 9:33 am
Offline  martinhutch
Share this post
Which tool? I've got some 32SC and the only unusual thing I used to get the lowers off was one of these, which most folk have lying around somewhere (bit holder for a drill).
Fits over the rebound bit that sticks out. Requires care, obviously.
Posted : 03/12/2019 9:47 am
Offline  beamers
Share this post
That works with the 32SC as well does it? I've seen that on a guide for the 34s and wasn't sure it would fit. What did you use to extend it with / manoeuvre it into place?
Posted : 03/12/2019 10:38 am
Offline  martinhutch
Share this post
I may have a faulty memory, but I don't recall it being too bad to get into the recess and have enough sticking out to hit with the hammer. Might have to check though!
Posted : 03/12/2019 10:54 am
Offline  beamers
Share this post
Mmm, that wouldn't have been a Step Cast fork then. With the driver on the rebound bits it will be right up inside the fork.
Posted : 03/12/2019 11:07 am
Offline  martinhutch
Share this post
It's definitely a Step Cast.
It's possible I had slightly longer driver to hand, although I've just popped a standard one up inside the recess (without removing the rebound knob) and it makes it to the end, just about. Small fingers help though.
Either way, 2 quid will be better than 30-60..
https://www.toolstation.com/magnetic-bit-holder-set/p99722?store=KG&utm_source=googleshopping&utm_medium=feed&utm_campaign=googleshoppingfeed&gclid=CjwKCAiArJjvBRACEiwA-Wiqq4dFO2rq-YvUkQ_wSSwfynrGXFuPm-yvnIlkDAs8DpityJYG-1MqrBoCmJUQAvD_BwE
Posted : 03/12/2019 11:31 am
Offline  bigyan
Share this post
Deep socket and an extension works (if you dont mind smacking the nut)
You can also drill and tap a bit of tube or bar to make copy of the fox tool.
Posted : 03/12/2019 11:37 am
Offline  beamers
