Fox 32 Float Step C...
[Closed] Fox 32 Float Step Cast - DIY lower leg removal
[#10943248]
Morning all
I'm after some advice on how to remove the lower legs on the above forks without shelling out for the specific Fox tool (£60.)
Has anyone got a handy work around? This is a bit more challenging with the Step Cast fork as the damper/spring assemblies are quite a long way up inside the lowers and not sticking out of the bottom as would be the case on a non Step Cast fork.
Any ideas? Ta in advance.
Posted : 03/12/2019 10:33 am
Which tool? I've got some 32SC and the only unusual thing I used to get the lowers off was one of these, which most folk have lying around somewhere (bit holder for a drill).
Fits over the rebound bit that sticks out. Requires care, obviously.
Posted : 03/12/2019 10:47 am
That works with the 32SC as well does it? I've seen that on a guide for the 34s and wasn't sure it would fit. What did you use to extend it with / manoeuvre it into place?
Posted : 03/12/2019 11:38 am
I may have a faulty memory, but I don't recall it being too bad to get into the recess and have enough sticking out to hit with the hammer. Might have to check though!
Posted : 03/12/2019 11:54 am
Mmm, that wouldn't have been a Step Cast fork then. With the driver on the rebound bits it will be right up inside the fork.
Posted : 03/12/2019 12:07 pm
It's definitely a Step Cast.
It's possible I had slightly longer driver to hand, although I've just popped a standard one up inside the recess (without removing the rebound knob) and it makes it to the end, just about. Small fingers help though.
Either way, 2 quid will be better than 30-60..
https://www.toolstation.com/magnetic-bit-holder-set/p99722?store=KG&utm_source=googleshopping&utm_medium=feed&utm_campaign=googleshoppingfeed&gclid=CjwKCAiArJjvBRACEiwA-Wiqq4dFO2rq-YvUkQ_wSSwfynrGXFuPm-yvnIlkDAs8DpityJYG-1MqrBoCmJUQAvD_BwE
Posted : 03/12/2019 12:31 pm
Deep socket and an extension works (if you dont mind smacking the nut)
You can also drill and tap a bit of tube or bar to make copy of the fox tool.
Posted : 03/12/2019 12:37 pm
