Where to begin….
I bought some forks ages ago on ebay, about this time last year.
Anyway, when i was fannying about yesterday i noticed some thread on the bolt…. The thread in the lower mount isn’t quite perfect. I’ve put in a longer bolt for now, but i’m considering my options.
Which leads me onto questions of course.
1. Time Sert v Helicoil…. Due to potential for removing the bolt after repair, i’m thinking Time Sert is a better option ?
2. Anyone have a Time Sert kit in an M6 to buy/borrow etc ?
If i don’t repair, then i’ll likley sell the forks on cheap (X-Fusion Sweep 140mm by the way) and replace with some new ones… But which forks…
Ideally i should go for 130’s as that’s what was fitted to the Whyte in the first place. But so many choices, i can never work out what order of sequence the Rockshox are for example and which are better ?
Pikes, Yaris, Revelations, Reba… .? Then you throw in various incarnations of Fox and the odd Manitou Minute comp, so many ‘which ones….’
Sadly i’m not seeing any of the bargain German suppliers with cheap 650B/27.5s at the moment, so not really sure what to do.
