As above, the battery packs are probably made from recycled laptops and generally useless. But the lamps themselves are sometimes OK, just ignore the lumen* figures. If it’s cheaper than the cheap but reputable brands (Magicshine, moon, nitefighter, etc) then they’ve cut something out, usually the battery.
*you can make an estimate by taking the quoted battery capacity in amp hours, and the run time in hours, divide one by the other to get the number of amps they’re running at. 7.4V x that = the power. Then go to the led manufacturers website and work out how many lumens that LED actually emits at that power (you may need to look at the driver current Vs forward voltage graph to determine the current from the power figure you just derived, then a second graph to convert that to lumens, then multiply that by ~0.8 to allow for the power supply, lens, reflector etc.)
